goodpranoy
Junior Member level 3
- Joined
- Dec 5, 2013
- Messages
- 29
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 201
i've written some codes in VHDL.
i am able to compile it, but during simulation the following warning occurs and i cannot get the desired results.
** Warning: (vsim-3473) Component instance "clk : clock_div" is not bound.
plz help.
plz help.
--top module
library ieee;
use ieee.std_logic_1164.all;
entity pc_rom_ent is
port(clock:in std_logic;
dout:out std_logic_vector(7 downto 0)
end pc_rom_ent;
architecture pc_rom_arch of pc_rom_ent is
signal pc_out:std_logic_vector(3 downto 0);
signal rom_out:std_logic_vector(7 downto 0);
signal clock_signal:std_logic;
component programcounter
output:out std_logic_vector(3 downto 0)
end component;
component rom
port(addr:in std_logic_vector(3 downto 0);
clock:in std_logic;
end component;
component clock_div
port ( CLKin: in std_logic;
CLKout: out std_logic
end component;
component instruction_register
port(data_in:in std_logic_vector(7 downto 0);
clock:in std_logic;
data_out:out std_logic_vector(7 downto 0));
end component;
begin
clk:clock_div
port map(CLKin=>clock,
CLKout=>clock_signal
ir:instruction_register
port map( data_in=> rom_out,
clock=>clock_signal,
data_out=>dout
pc:programcounter
port map(
output=>pc_out
mem:rom
port map(
addr=>pc_out,
dout=>rom_out
end pc_rom_arch;
--clock divider
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity clock_div is
end clock_div;
architecture arch of clock_div is
signal counter: integer:=1;
signal temp : std_logic := '1';
begin
process(CLKin,counter)
begin
--if(reset='0') then counter<=0; temp<='1';
--els
if(CLKin'event and CLKin='1') then counter <=counter+1;
if (counter = 1) then temp <= NOT temp; counter<=0;
end if;
end if;
CLKout <= temp;
end process;
end arch;
--instruction register
library ieee;
entity instruction_register is
clock:in std_logic;
end instruction_register;
architecture ir of instruction_register is
begin
process(clock)
begin
data_out<="ZZZZZZZZ";
-- +ive edge triggered --
if(clock = '1') and (clock'event) then
data_out <= data_in ;
-- for async reset --
else
data_out <= (others => 'Z') ;
end if;
end process;
end ir ;
--ROM
library ieee;
use ieee.std_logic_unsigned.all;
entity rom is
clock:in std_logic;
dout:out std_logic_vector(7 downto 0));
end rom;
architecture beh123 of rom is
type rom_arr is array(0 to 15)of std_logic_vector(7 downto 0);
constant mem:rom_arr:=
( "UUUUUUUU","UUUUUUUU","10100010","UUUUUUUU","UUUUUUUU","UUUUUUUU","00000110","UUUUUUUU","01001000","01001001","UUUUUUUU","00101011","UUUUUUUU","UUUUUUUU","UUUUUUUU","UUUUUUUU");
begin
process(clock)
begin
if (clock'event and clock='1') then
dout<=mem(conv_integer(addr));
end if;
end process;
end beh123;
--program counter
library ieee;
entity programcounter is
end programcounter;
architecture pc_arch of programcounter is
begin
process(clock)
variable pc_int:std_logic_vector(3 downto 0):="0000";
begin
if clock'event and clock='1' then
pc_int:=(pc_int+1);
end if;
output<=pc_int;
end process;
end pc_arch;
