ramesh28
Member level 3
- Joined
- May 21, 2013
- Messages
- 57
- Helped
- 1
- Reputation
- 2
- Reaction score
- 1
- Trophy points
- 1,288
- Activity points
- 1,670
Hello all,
following is the warning occured during placement stage to me.
Exception -to pin i2c_x_i2c_wr_auto_switch/g1063/B2 for exception 124 is not a timing end point - ignoring. Use
"config_timing -strict_exception_from_to false" to override.
Exception -from pin x_spcdac2/dspd/gen_cram_dspd_cram/U_mbisted_ram/ram_46x16_bist_ram_46x16_block_instance_0/ram_46x16_instance_0/CLKB for exception 129 is not a timing start point - ignoring. Use "config_timing -strict_exception_from_to false" to override.
Please suggest me solution on this..what i have to do?
Thank you..
Actually i found that these pins set as set_false_path under .sdc file.
so tell me now what i should do..? Can go forward in flow or i remove these set_false_path?
guide me..
Thank you..
Thank you..
guide me..
Thank you..
