warning in quartus About pin
esielec
Newbie level 6
Newbie level 6
hello,
warning in quartus
The specified number of pins in the design have no exact pin location assignments. For example, the pin may be assigned to a specific I/O bank. This information is provided to show which pins you can assign to a location on the device. Click the + icon in the Messages window or the Messages section of the Report window to display details on the specific nodes that have not been assigned a location
Makes the synthesis of a few hours last?????!!!!!
What should I do?please help me
You are quoting Quartus help for a warning like
Critical Warning (169085): No exact pin location assignment(s) for 2 pins of 2 total pins
If this is the only warning, your design apparently compiled correctly.
What are you trying to achieve? If you're compiling a FPGA design for a development board, it's pin mapping should be imported prior to compilation.
If it's your own hardware, you should know how FPGA pins are connected. Make it known to Quartus, e.g. by using the PinPlanner tool.
If it's just a test compilation, nothing to do.
my cod
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
entity ghj is
port(clk,rst:in std_logic;
     bw:in std_logic ;
--	  a:out std_logic ;
--     test:out integer range 0 to 105;
     g:out std_logic_vector(6 downto 0);
--	  testrma,outrma:out std_logic_vector(4 downto 0);
	  rma:in std_logic_vector(4 downto 0);
	  wrmap,rcvrmap:out std_logic;
	  wr:out std_logic
	  end;
	  architecture detect of ghj  is
	 -- type im1x is array(0 to 63) of std_logic  ;
	 -- type im2x is array (0 to 58)of im1x;
	  type im3x is array(0 to 103) of integer range 0 to 64 ;
	  type im4x is array (0 to 98)of im3x;
--	  type im5x is array (0 to 40)of integer range 0 to 20;
--	  type im6x is array (0 to 40)of im5x;
--     signal rmap:im6x;
	  signal hough:im4x;
	 -- signal im:im2x;
	  type vec1x is array (0 to 160) of integer range 0 to 64;--mishe 200 ya kamtar gereft hadaqal 151
	  signal edgx,edgy:vec1x;
	  type vec2x is array (0 to 2)of integer range 0 to 105;
     signal circlec,circlex,circley,circler:vec2x;
	  type vec3x is array (0 to 111)of integer range 0 to 41;
	  type vec4x is array (0 to 115)of integer range 0 to 41;
	  signal R18x,R18y,R20x,R20y:vec3x;
	  signal R19x,R19y:vec4x;
    -- type vec2x is array (0 to 68) of integer range 0 to 40;
	  --signal rmapx,rmapy:vec2x;
	  type state_machine is(s1_rcv,s2_write, s4_rcvrmap,
									 s6_start,s7_findr,s8_index,
									s9_chek,s10_R18,s12_R20,s11_R19,s15,s16);
	  signal  wr1,wr2:std_logic:='1';
	  signal  state:state_machine:=s1_rcv;
	  signal  rmapx,rmapy:integer range 0 to 41:=0;
	  signal  p:integer range 0 to 104;
	  signal  h:std_logic_vector(6 downto 0);
	--  signal  Rrow:integer range 0 to 3:=0;
	  begin
	  process(clk)
	  variable Rrow:integer range 0 to 3:=0;
	  variable row,indexx:integer range 0 to 99:=0;
	  variable clm,indexy:integer range 0 to 104:=0;
	  variable i,counter:integer range 0 to 160:=0;
	  variable R:integer range 17 to 21:=17;
	  variable k,v,j:integer range 0 to 125:=0;
	  begin
	  if (clk'event and clk='1') then
				if(rst='1')then
						if(state=s1_rcv) then
								if(clm>63) then
										clm:=0;
										row:=row+1;
								end if;
								if(row<59) then
									--im(row)(clm)<=bw;
                              if(bw='1') then
										edgx(i)<=row;
										edgy(i)<=clm;
										i:=i+1;
									   end if;
--										sum  <=bw;
										clm:=clm+1;
								else
										state<=s4_rcvrmap;
										clm:=0;
										row:=0;
										rcvrmap<='1';
								end if;
						elsif(state=s4_rcvrmap)then
								if(clm>40) then
										clm:=0;
										row:=row+1;
								end if;
								if(row<41) then
										if(rma="10010")then
										R18x(j)<=Row;
										R18y(j)<=clm;
										j:=j+1;
										end if;
										if(rma="10011")then
										R19x(k)<=Row;
										R19y(k)<=clm;
										k:=k+1;
										end if;
										if(rma="10100")then
										R20x(v)<=Row;
										R20y(v)<=clm;
										v:=v+1;
										end if;
										clm:=clm+1;
								else
										state<=s6_start;
										clm:=0;
										row:=0;
										v:=0;
										k:=0;
										j:=0;
										rcvrmap<='0';
										wrmap<='1';
								end if;
						elsif(state=s6_start)then --sefr kardan hough
								if(clm>103) then
										clm:=0;
										row:=row+1;
								end if;
								if(row<99) then
										hough(row)(clm)<=0;
										clm:=clm+1;
								elsif(R<20)then
										R:=R+1;
										state<=s7_findr;
										clm:=0;
										row:=0;
								else
										state<=s2_write;  --kharej shodan az halqe tabdil hough
										clm:=0;
										row:=0;
										Rrow:=0;
								end if;
						elsif(state=s7_findr)then --peida kardane R haye khas
								if(R=18)then
								state<=s10_R18;
								end if;
								if(R=19)then
								state<=s11_R19;
								end if;
								if(R=20)then
								state<=s12_R20;
								end if;
						elsif(state=s10_R18)then
								if(j<112)then
										rmapx<=R18x(j);
										rmapy<=R18y(j);
										j:=j+1;
										state<=s8_index;
								else
										j:=0;
										state<=s6_start;
								end if;
						elsif(state=s11_R19)then
								if(k<116)then
										rmapx<=R19x(k);
										rmapy<=R19y(k);
										k:=k+1;
										state<=s8_index;
								else
										k:=0;
										state<=s6_start;
								end if;
						elsif(state=s12_R20)then
								if(v<112)then
										rmapx<=R20x(v);
										rmapy<=R20y(v);
										v:=v+1;
										state<=s8_index;
								else
										v:=0;
										state<=s6_start;
								end if;
						elsif(state=s8_index)then--ezafe kardan be matris hough
								if(counter<i)then--sakht inex
										indexx:=edgx(counter)+rmapx-1 ;
									indexy:=edgy(counter)+rmapy-1;
									hough(indexx)(indexy)<=hough(indexx)(indexy)+1; --ezaf kardan hough marbor be R
										counter:=counter+1;
								else
								state<=S9_chek;
								counter:=0;
								end if;
						elsif(state=s9_chek)then--hazfe meqdarhayi ke az treshhold meqdar kamtari daran
								if(clm>103) then
										clm:=0;
										row:=row+1;
								end if;
								if(row<99) then
										if(hough(row)(clm)>60)then
										circlex(Rrow)<=row;
										circley(Rrow)<=clm;
										circlec(Rrow)<=hough(row)(clm);
										circler(Rrow)<=R;
										Rrow:=Rrow+1;
										end if;
										clm:=clm+1;
								else
										state<=s6_start;  --kharej shodan az halqe tabdil hough
										clm:=0;
										row:=0;
								end if;
						elsif(state=s2_write)then --write the image in fail txt
											p	<=circlex(Rrow);
											state<=s15;
						elsif(state=s15)then
							h<=conv_std_logic_vector(p,7);
			            state<=s16;
					   elsif(state=s16)then
	 				   g<=h;
						end if;
				else
				      wr<='0';
				end if;
		end if;
	  end process;
	end;
not Synthesis,
And it was not compiled
But when I clean g<=h;(Finally Code) it was synthesized in 20 seconds
not Synthesis,
The problem isn't related to the original thread topic. This is the error I see with your posted code.
Error (276003): Cannot convert all sets of registers into RAM megafunctions when creating nodes. The resulting number of registers remaining in design exceeds the number of registers in the device or the number specified by the assignment max_number_of_registers_from_uninferred_rams. This can cause longer compilation time or result in insufficient memory to complete Analysis and Synthesis
I guess that the design isn't actually suited to be synthesized in a FPGA and needs much more than small cosmetic corrections.
Once the clear line that only one percent of IC which is used cylcon??
Yes, by commenting the line, the data output is disconnected from your design, which causes Quartus to discard most of the design logic during synthesis.
Surely not the intended solution.
incompatible definitions for +/- etc.
For the rest of the code you wrote a hardware description like you would try writing it in C. If you want to write it as a software description then use a processor and a C compiler and don't write VHDL.
Logically I don't think your code is correct even for software. There are areas where counters don't get initialized back after reaching their terminal values.
Using a state machine to update the arrays isn't going to implement memories, which is what you need to use. Basically this isn't designed to implement an efficient hardware solution.
I changed the code.
I can not but lead output
It(test<=CONV_INT2STDLV(circlex(0),8);) was clear when I synthesis code!!!!
library ieee;
entity migmig is
     bw:in std_logic ;
	  rcvim:out std_logic;
	  test:out std_logic_vector(7 downto 0);
end;
architecture esi of migmig is
function CONV_INT2STDLV(ARG: INTEGER; SIZE: INTEGER)
return STD_LOGIC_VECTOR is
variable result: STD_LOGIC_VECTOR (SIZE-1 downto 0):=x"00";
variable temp: integer:= 0;
begin
	temp := ARG;
	for i in 0 to SIZE-1 loop
	    if ((temp mod 2) = 1) then
			result(i) := '1';
	    else
			result(i) := '0';
	    end if;
	    if temp > 0 then
			temp := temp / 2;
	    elsif (temp > integer'low) then
			temp := (temp - 1) / 2; -- simulate ASR
	    else
			temp := temp / 2; -- simulate ASR
	    end if;
	end loop;
	return result;
end CONV_INT2STDLV;
	  signal hough:im4x;
	  type state_machine is(s0_start,s1_rcvim,s2_rcvrmap,s3_index,s4_chek,s7_write);
	  signal  state:state_machine:=s0_start;
--	  signal  rmapx,rmapy:integer range 0 to 41:=0;
	  signal edgx,edgy:integer range 0 to 63;
	  signal test1:std_logic_vector(7 downto 0);
begin
 process(clk)
	  variable row2,clm2,r19x,r19y:integer range 0 to 41:=0;
--	  variable counter:integer range 0 to 160:=0;
--	  variable R:integer range 17 to 21:=17;
begin
				if(rst='1')then
						if(state=s0_start)then
								if(clm>103) then
										clm:=0;
										row:=row+1;
								end if;
								if(row<99) then
										hough(row)(clm)<=0;
										clm:=clm+1;
								else
										state<=s1_rcvim;  --kharej shodan az halqe tabdil hough
										clm:=0;
										row:=0;
										rcvim<='1';
								end if;
						elsif(state=s1_rcvim) then
								if(clm>63) then
										clm:=0;
										row:=row+1;
								end if;
								if(row<59) then
                              if(bw='1') then
										edgx<=row;
   									edgy<=clm;
										rcvim<='0';
										state<=s2_rcvrmap;
										rcvrmap<='1';
--										i:=i+1;
									   end if;
										clm:=clm+1;
								else
									   state<=s4_chek;
										clm:=0;
										row:=0;
									   rcvim<='0';
								end if;
						elsif(state=s2_rcvrmap)then
									if(clm2>40) then
										clm2:=0;
										row2:=row2+1;
								end if;
								if(row2<41) then
										if(rma="10011")then
										R19x:=Row2-1;
										R19y:=clm2-1;
										rcvrmap<='0';
										state<=s3_index;
										end if;
										clm2:=clm2+1;
								else
										state<=s1_rcvim;
										clm2:=0;
										row2:=0;
										rcvim<='1';
										rcvrmap<='0';
								end if;
							elsif(state=s3_index)then
										indexx:=R19x+row;
										indexy:=R19y+clm;
										state<=s2_rcvrmap;
										rcvrmap<='1';
							elsif(state=s4_chek)then
										if(clm>103) then
										clm:=0;
										row:=row+1;
										end if;
										if(row<99) then
														circlex(Rrow)<=row;
														circley(Rrow)<=clm;
--														circler(Rrow)<=R;
														Rrow:=Rrow+1;
												end if;
										clm:=clm+1;
										else
										state<=s7_write;  --kharej shodan az halqe tabdil hough
										clm:=0;
										row:=0;
										Rrow:=0;
										end if;
							elsif(state=s7_write)then
							end if;--of state
				rcvim<='0';
				rcvrmap<='0';
					end if;-- of rst
		end if;-- of clk
end process;
end;
