warning in hfss what does it mean and how to correct them
kartikkhurana
Full Member level 3
cpw jodhpur1 (C:/Users/Kirti/Documents/Ansoft/)
HFSSDesign1 (DrivenModal)
[warning] Warning - Boundary 'PerfE1' and Boundary 'PerfE2' overlap. (1:22:49 PM Jul 09, 2012)
[warning] Warning - Boundary 'PerfE4' and Boundary 'Rad1' overlap. (1:35:15 PM Jul 09, 2012)
[error] Simulation was aborted by user on server: Local Machine. (1:40:50 PM Jul 09, 2012)
[warning] Boundary 'PerfE4': Boundary lost its assignment due to geometry modifications and has been deleted. (1:46:56 PM Jul 09, 2012)
[warning] Port '1': One or more port lines were lost due to geometry modifications. (1:46:56 PM Jul 09, 2012)
[warning] Port '1': Port lost its assignment due to geometry modifications and has been deleted. (1:46:56 PM Jul 09, 2012)
[info] Port refinement, process hf3d: Too many conductors touch lumped port '1'. Consider splitting the port into multiple lumped ports (1:51:43 PM Jul 09, 2012)
[info] Port refinement, process hf3d: Too many conductors touch lumped port '1'. Consider splitting the port into multiple lumped ports (1:51:44 PM Jul 09, 2012)
[info] Port refinement, process hf3d: Too many conductors touch lumped port '1'. Consider splitting the port into multiple lumped ports (1:51:45 PM Jul 09, 2012)
[info] Port refinement, process hf3d: Too many conductors touch lumped port '1'. Consider splitting the port into multiple lumped ports (1:51:46 PM Jul 09, 2012)
[info] Port refinement, process hf3d: Too many conductors touch lumped port '1'. Consider splitting the port into multiple lumped ports (1:51:47 PM Jul 09, 2012)
[info] Adaptive solution setup, process hf3d: Too many conductors touch lumped port '1'. Consider splitting the port into multiple lumped ports (1:54:02 PM Jul 09, 2012)
[error] Adaptive solution setup, process hf3d error: Matrix solver exception: out of memory, please verify Desired/Maximum RAM Limit setting.. (2:01:02 PM Jul 09, 2012)
[error] Simulation completed with execution error on server: Local Machine. (2:01:20 PM Jul 09, 2012)
[info] Adaptive solution setup, process hf3d: Too many conductors touch lumped port '1'. Consider splitting the port into multiple lumped ports (2:14:33 PM Jul 09, 2012)
[error] Adaptive solution setup, process hf3d error: Matrix solver exception: out of memory, please verify Desired/Maximum RAM Limit setting.. (2:26:54 PM Jul 09, 2012)
[error] Simulation completed with execution error on server: Local Machine. (2:27:35 PM Jul 09, 2012)
