Inkidu
Newbie level 5
Re: Want to switch from a cordless mower to a corded one. B&
Thanks for the help everyone. Points well taken.
Might need a large amount of amps at any one time.
So how about (2) 123A developer packs and use 8 cells to make a pack.
Obviously some things I need to research. I have found some info
on how to solder if you have a nice solder station, which I have.
Couple ?'s Do Ah add up like volts when cells are put in a series?
That is to say for instance do the (2) 17Ah batteries I have now
actually give 34Ah of use when connected in series?
It seems that charging can become a problem with Li-PO4 cells.
Is that true with all Li-PO4 batteries including the ones 123a sells.
I have seen Protection Circuit Module that are designed specifically for the
previously mentioned LiFePO4 cells(previous post), but could I just make (2)
smaller 4 cell packs that I could plug in series when I go to use them but
charge them separately. Obviously I won't hold anyone accountable for some
fairly significant bad repercussions. From what I have read these are the safest
Li-ion batteries out there and 123A have the best made of the LiFePO4 cells.
Maybe some good links on what to do and not to do might be helpful?
Researching something can be half the fun.
Thanks for any help.
