the (17ah)capacity its mean you can run load on battery with 17a or 408 watt for one houre
No.so if I went to big could the motor draw to much and then burn up?
hi...KMoffett said:the (17ah)capacity its mean you can run load on battery with 17a or 408 watt for one houre
Actually most AH ratings are based on 1/10 the current draw of the AH spec. You can ran a 17AH battery at 1.7 A for 10 Hours. You will not be able to run it at 17A for 1 hour.
ken
Inkidu said:Not that I don't believe you about the amps and I appreciate the input but there
are only (2) 17ah batteries and this mower can easily go 4 hours without a
charge.
