[SOLVED] Want to know details of LPC2148 PLL
nikhillife11
Member level 2
Hey All,
I need your help. I am currently working on LPC2148 and trying to write my program for LCD. I googled some pages and came accros a common function for initializing PLL of LPC2148
But my question is.... If i am using a 12 MHZ crystal at the xtal1 and xtal2 pin of LPC2148,what will the CPU clock be and Peripheral clock be from below function
void clkinit(void)
PLL0CFG=0x24;
PLL0FEED=0xAA;
PLL0FEED=0x55;
PLL0CON=0x01;
PLL0FEED=0xAA;
PLL0FEED=0x55;
while(!(PLL0STAT & PLOCK));
PLL0CON=0x03;
PLL0FEED=0xAA;
PLL0FEED=0x55;
MAMCR=0x02; // why this initialization
MAMTIM=0x04; // Again why this one
VPBDIV=0x01;
I need to know my CPU and Peripheral clock to calculate the approx. delay.
So pl. help me out friends
thanks
Nikhil
void clkinit(void)
PLL0CFG=0x24;
PLL0FEED=0xAA;
PLL0FEED=0x55;
PLL0CON=0x01;
PLL0FEED=0xAA;
PLL0FEED=0x55;
PLL0CON=0x03;
PLL0FEED=0xAA;
PLL0FEED=0x55;
VPBDIV=0x01;
Fosc = 12MHz
MSEL bits (00100) -> Value of M = 5
PSEL bits (01) -> Value of P = 2
The above values load into PLL0CFG=0x24
Therefore:
CCLK = 60MHz
Fcco = 240MHz
If VPBDIV = 1, then the core clock CCLK = PCLK the peripheral clock.
PCLK = 60MHz
Concerning the following parameters:
MAMCR=0x02; // enables memory accelerator module
MAMTIM=0x04; // configures MAM fetch cycles
You can find additional information relevant to the LPC2148 and PLL configuration in the following documents:
Getting Top Performance from NXP's LPC Processors
Clocking ARM with Crystal oscillator and PLL
BigDog
Fosc = 12MHz
Therefore:
CCLK = 60MHz
Fcco = 240MHz
PCLK = 60MHz
BigDog
Hello BigDog,
I just dint understand those memory accelerator module, So do you have any specific document to elaborate MAM and make it simple to understand.
Please help
Thanks
Nikhil
Sure.
The Memory Accelerator Module (MAM) is essential a cache system used to bridge the gap between the speed limitation of Flash Memory and the much higher clock frequencies of the ARM7TDMI Core.
Due to system startup and boot requirements, the MAM as with most caching systems is disabled on reset. Therefore to run the ARM7TDMI core at a much higher clock frequency than the Flash Memory can be accessed, the MAM or other cache system must be enabled as well.
LPC2000 MCU memory acceleration module
Peripheral Simulation For NXP (founded by Philips) LPC2148 — Memory Accelerator Module (MAM)
Hope these links and PDFs help your understanding.
BigDog
