walsh code matrix generation using vhdl
Prathibha R
Hello,
I'm trying to write code for 64*64 walsh code matrix using hadamard recursive algorithm.The code is below.I'm getting some syntax error in 2d matrix declaration.Please help me.The error what i am getting is Type integer is not an array type and cannot be indexed.
Code VHDL - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
use ieee.numeric_std.all;
USE ieee.std_logic_arith.all;
package test is
subtype word is integer;
type strng1 is array (0 to 63) of word;
type strng2 is array (0 to 63) of strng1;
end test;
library ieee;
use ieee.std_logic_1164.all;
use work.test.all;
entity walsh is
port(N,M:inout strng2);
end walsh;
architecture Behavioral of walsh is
begin
process
constant A:integer:=64;
variable z:integer:=1;
variable m,n,x:integer;
begin
x:=(2**z);
for i in 0 to x-1 loop
for j in 0 to x-1 loop
if((i=j) and (j=1)) then
M(i)(j)<=1;
else
M(i)(j)<=0;
end if;
end loop;
end loop;
z:=z+1;
x:=(2**z);
while(x<=A) loop
m:=i mod (2**(z-1));
n:=j mod (2**(z-1));
if((i>=(2**(z-1))) and (j>=(2**(z-1)))) then
N(i)(j)<=not M(m)(n);
else
N(i)(j)<= M(m)(n);
end if ;
end loop;
end loop;
M(i)(j)<= N(i)(j);
end loop;
end loop;
z:=z+1;
x:=(2**z);
end loop;
end process;
end Behavioral;
PHP:
VHDL is not case sensitive, you can't have m,n and M,N
also there is no not operand for integer
N(i)(j)<= not M(m)(n);
also do not use together
use only numeric_std.
and overall this code looks like C sw code not hw
Revised walsh code matrix generation
Hello,
I have writtten the vhdl code for generation of 64*64 walsh code matrix.While synthesizing I am getting an error in 2nd for loop.The error is Range bound must be a constant.Here is my program.Please help me to debug the code.Thank you.
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
package test is
subtype word is bit;
type strng1 is array (0 to (A-1)) of word;
type strng2 is array (0 to (A-1)) of strng1;
end test;
library ieee;
--USE ieee.std_logic_arith.all;
use work.test.all;
entity walsh is
port( N,M:  inout strng2 );
end walsh;
begin
process
--variable N,M: strng2;
variable c,d,x:integer;
begin
x:=(2**z);
for i in 0 to 1 loop
for j in 0 to 1 loop
if((i=1) and (j=1)) then
M(i)(j)<='1';
else
M(i)(j)<='0';
end if;
end loop;
end loop;
z:=z+1;
x:=(2**z);
while(x<=A) loop
c:=i mod (2**(z-1));
d:=j mod (2**(z-1));
N(i)(j)<=not M(c)(d);
else
N(i)(j)<= M(c)(d);
end if ;
end loop;
end loop;
M(i)(j)<= N(i)(j);
end loop;
end loop;
z:=z+1;
x:=(2**z);
end loop;
end process;
end Behavioral;
The error is correct. VHDL is not software. For loops are unrolled into parrallel hardware, so for synthesis loops must use constant values.
