voltmeter using pic 16f877a problem
madogas
Junior Member level 3
hi i have problem the voltmeter dose not give me right reading when the input is 9 the reading is 30.9 when i test it with avometer across 20k its reads 9 but the lcd reads 30.9 ... help me
                              // LCD module connections
sbit LCD_RS at RB5_bit;
sbit LCD_EN at RB7_bit;
sbit LCD_D4 at RC4_bit;
sbit LCD_D5 at RC5_bit;
sbit LCD_D6 at RC6_bit;
sbit LCD_D7 at RC7_bit;
sbit LCD_RS_Direction at TRISB5_bit;
sbit LCD_EN_Direction at TRISB7_bit;
sbit LCD_D4_Direction at TRISC4_bit;
sbit LCD_D5_Direction at TRISC5_bit;
sbit LCD_D6_Direction at TRISC6_bit;
sbit LCD_D7_Direction at TRISC7_bit;
// End LCD module connections
char look(int a)
   switch(a)
       case 0:
              return '0';
       case 1:
              return '1';
       case 2:
              return '2';
       case 3:
              return '3';
       case 4:
              return '4';
       case 5:
              return '5';
       case 6:
              return '6';
       case 7:
              return '7';
       case 8:
              return '8';
       case 9:
              return '9';
       default:
              return '.';
void main()
  unsigned int v,vp,ip,i;
  char *volt = "00.0";
  char *current = "0.00";
  TRISA  = 0xFF;
  Lcd_Init();
  Lcd_Cmd(_LCD_CLEAR);
  Lcd_Cmd(_LCD_CURSOR_OFF);
  do
       ADCON1 = 0x00;
       v = ADC_Read(2);
       i = ADC_Read(3);
       i = (i*4.8828)/0.47;
       v = ((v*4.8828)/20)*120;
       if(v!=vp || i!=ip )
       vp = v;
       ip = i;
       volt[0] = look(v/10000);
       volt[1] = look((v/1000)%10);
       volt[3] = look((v/100)%10);
       Lcd_Out(1,1,"Voltage = ");
       Lcd_Out(1,11,volt);
       Lcd_Out(1,16,"V");
       current[0] = look(i/1000);
       current[2] = look((i/100)%10);
       current[3] = look((i/10)%10);
       Lcd_Out(2,1,"Current = ");
       Lcd_Out(2,11,current);
       Lcd_Out(2,16,"A");
       Delay_ms(250);
  } while(1);
Hi there,
Are you sure about this function look(v/10000);??
for current and voltage division why are you using different logic??
update me,
Best regards.
the rang is 0 to 30v and 3A current .
that is right ligo.george but it is not working correct with me idont know why
this the the project folder
  • voltmeter1.rar
Try this.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
float v, i , vp, ip;
unsigned char volt[23], current[23];
void main()
      TRISA  = 0xFF;
      ADCON1 = 0b10001001;
      CMCON = 0x07;
      CVRCON = 0x00;
      Lcd_Init();
      Lcd_Out(1,1,"V = ");
      Lcd_Out(2,1,"I = ");
      do
           v = ADC_Read(2);
           i = ADC_Read(3);
           if(v!=vp || i!=ip ){
                 v = v * 30.0 / 1023.0;               //ADC 5V input means 30 V and 1023 raw adc value
                 i = i * 3.0 / 1023.0;                //ADC 5V input means 3 A and 1023 raw adc value
                 FloatToStr(v, volt);
                 FloatToStr(i, current);
                 strncat(volt," V",2);
                 strncat(current," A",2);
                 Lcd_Out(1,5,volt);
                 Lcd_Out(2,5,current);
                 vp = v;
                 ip = i;
                 Delay_ms(250);
      } while(1);
It is showing 30V and 3A when adc inputs are 5V. It is right. There is some other problem. Draw the circuit in proteus and zip and post it here. The circuit is wrong. I is always 0. V is showing 30 V.
no the volt that i want to measured is 12 v when i connect it the result 30v
Post your exact circuit. Earlier you said that range is 30 V and 3 A. Mention properly the range of V and I you want to measure.
Replace the 100k resistor to 1.82k and 20k by 1.3k.
Code C - [expand]
v = v * 12.0 / 1006.999;                //ADC 5V input means 12 V and 1023 raw adc value
i = i * 3.0 / 1006.999;                //ADC 5V input means 3 A and 1023 raw adc value
i want to measure from 0 to 30v the current from 0 to 10 A is the circuit that i send it before can do this
the hardware is that i send it before maybe the 4MHz crystal is the problem in the original project he use 8 MHz
Maybe you are using cra***d mikroC Compiler and it is creating wrong hex file. Try the hex file attached. It should give right value of V for your circuit.
  • vm.rar
