voltage-to-current converter chip for oscilloscope XY mode for curve tracing?
Using a oscilloscope in XY mode is voltage verically and voltage horzontally
My goal is to use the oscilloscope to do curve tracing or component characterists like what a signature analysis test gear does
If i put my oscilloscope in XY mode and try to measure a resistor it doesn't Curve trace, if i try to measure a capacitor it doesn't curve trace either
Do you have to hook up a AC generator to the resistor or capacitor when doing curve tracing on the oscilloscope?or use a power supply hookup up to the component being curved trace?
So channel #1 on the oscilloscope is set to the vertical display for voltage
Channel#2 on the oscillscope is set to horizontial display for voltage
If i use a voltage to current converter chip on channel#2 will the oscilloscope be able to do V/I curve tracing? (i would need a current oscilloscope probe too)
