tiwari.sachin
Full Member level 6
Hello,
Have designed a board that requires a supply of 7.4v/3 amps to the circuit.
The board has options to power from mains as well as through the battery (Li Ion)
Purpose of switching circuit is as folllow.
When main power is present, the board is powered through Mains and when its not present, the supply is switch to battery and vice versa.
Concerns
1. The SMPS that I have used is 9.5v/3amps. Consider this to be mains supply and because I need 7.4V, I am dropping it via 2 series Diode (1N5408) but these are heating up when the load takes up 2.5amps plus....
2. During switching between mains and power supply, it all works fine but if I connect the mains power via DC Jack (Normally available for SMPS), the controller board resets. If I keep the DC jack plugged in continuously without removing or plugging it back, it still works fine.
I get controller reset during plugging in the DC Jack/ I am assuming it is some spike that is generated when I plug the DC jack. How can I solve issues like this.
Sachin....
Concerns
Sachin....
