Just wanted to know if there is any way to calculate the impedance of a structure when excited by a voltage source in HFSS. I tried running a simulation and all I get are field values at each frequency point. There are no other variables for plotting in the results menu. Is there a way to calculate the impedance of the structure using the calculator?
Any insight/advice/solution would be of great help!
You can use the fields calculator to calcuate the complex current and then knowing the magnitude and phase of the voltage you can calculate the impedance. I have been trying to do this with a dipole my self. Our set ups sound similar but I am just using a voltage source between the two cylinders and then measuring the current right at the center of the voltage source line. I haven't been able to get it to work consistently but in theory it should work.
