Hi friends....
Does anyone uses the NI Circuit Design Suit 11.0?????
I am having a problem in designing a voltage regulator with a BT136 triac.... I have decompiled the circuit by reading the values of components & connections from a fan regulator circuit... My readings are correct and I designed the same circuit in NI Circuit Design Suit 11.... But my simulation result is not as it was supposed to be....
The output voltage should drop, but it is not so...
Could anyone tell me if there is anything wrong in my working.....
