asrock70
Full Member level 4
At the beginning, I will describe what I am talking about.
I need, among other things, to control the performance of two 230V heaters (700W each).
Power control in the range of 0-100 percent.
Power control from MCU (somewhat STM32).
It is not a serial production (approx. 3 pieces), requirements, cheap, simple, galvanically separated.
The first thing that came to mind is to use SSVR any as this.
Unfortunately, I don't have 10V or even a reliable 5V available. Making a current loop at 4.5V probably won't be easy either,
Plus the prices, even from China, are not what they used to be
Design your own control board.
What comes to my mind
ZCD any as this
Triac any as BTA16, optotriac any as MOC305x
Any smal MCU with 2 PWM input for transmitting information about the required performance.
The MCU then flashes the LED in the optotriac according to the information from the ZCD.
I don't know, maybe someone is offering it on ALi or Ebay, maybe I'm making something up.
Do you handle it?
Thanks
ZCD any as this
Do you handle it?
Thanks
