Pheetuz
Full Member level 3
Im currently doing a project that involves me running two 12V motors and several IC's off of one 12V drill battery, there is no current limiter on the battery itself.
What i was wondering is, will the voltage from the battery drop when the motor draws current from it? As that is what seems to be happening when i use a normal power supply, although i know the current from these is limited. - the voltage seems to fluctuate from between 12V and about 5V.
Basically, if the voltage starts to drop then its going to cause mayhem around the rest of the circuit, although the IC's are on the other side of a regulator with 2x decoupling caps, it wont really help if the voltage drops by a lot.
Someone on here suggested using a bulking capacitor in parrallel with my normal decoupling capacitors next to the IC's to help them stay powered when the motors draw current but thats not going to help my transistors that are activating my relay coils etc.
Basically just wondering if the voltage will drop??
Many thanks folks
/Pete
Many thanks folks
/Pete
