Circuit Learner
Junior Member level 1
For example, say I have 5 batteries in series. Each battery is connected by 1 foot of wire for a total of 4 feet. Each battery has 4 volts for a total voltage of 20 volts.
My load will use a constant current.
When calculating voltage drop in the 4 feet of wire, would I use:
total voltage of the series of batteries. 16 volts?
An average of the total voltage of series. 8 volts?
Or some other value?
The question is basically about how the voltage moves across the wire connecting the batteries, is it equal, or is the voltage different depending on where the wire is in the series.
Thanks.
Thanks.
