The_Babatian
Junior Member level 2
- Joined
- Feb 22, 2013
- Messages
- 22
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,483
Hi All,
I am designing a digitally controlled boost converter. I have trouble with the voltage divider used to scale down the output voltage to fit the input range of the on-chip ADC of the Microcontroller (TMS320F28335) from TI. I noticed that the voltage divider ratio was at desired value when the output of the voltage divider was not connected to the ADC input node, but the voltage divider ratio increased a lot when when the output of the voltage divider was connected to the ADC input node.
I was wondering if this is caused by the input impedance of the ADC, so I tried to put a 0.1uF ceramic capacitor in parallel with the input of the ADC, but it did not make any difference.
Can anyone help me out on this issue? thanks in advance.
