circuit_hunter
Junior Member level 3
Hi
I have to use two distinct models depending upon the node voltage, something as follows:
The diodes D1 and D2 have different properties/models. If the voltage at node v1>0, then I want node v1 to be connected (perfectly shorted) to the D1 (as if D2 is not there at all), otherwise to D2 (as if D1 is not there at all).
I wonder if this kind of voltage dependednt use of model would be possible in Keysight the ADS? In fact, I have tried it using SDD as shown in the following:
But, I am not sure if SDD results into a perefctly shorted connection. I guess, it "shields" the parasitics of diodes from rest of the circuit.
(1) If my way of using SDD in this scenerio corect?
(2) If not, what else could be a better solution?
Thanks in advance.
Thanks in advance.
