Viterbi Decoding Error
Abhijith Yadav
Junior Member level 3
Kozhikode, India
Hey people,
I am working on viterbi decoding in vhdl. I am using altera quartusII 6.0. I am posting the code and the problem, please help me rectifyy ut
library ieee;
library work;
use ieee.std_logic_unsigned.all;
use ieee.std_logic_1164.all;
use work.data_packages.all;
entity viterbi_decode is
	port (path_calc: buffer statehist_data;
		  enc_data : in std_logic_vector(1 downto 0);
		  clock    : in std_logic;
		  xor_out  : buffer output_data;
		  pm       : buffer pmetric;
		  path	   : buffer statehist_data;
		  pathfinal: out std_logic_vector(14 downto 0));
end viterbi_decode;
architecture func of viterbi_decode is
component A is
port (xor_out               : buffer output_data;
	  bm                    : in  bmetric;
	  pathmetricA           : buffer integer range 0 to 1023;
      pm                    : out pmetric);
end component;
component B is
	  bm                    : in  bmetric;
	  pathmetricB           : buffer integer range 0 to 1023;
      pm                    : out pmetric);
end component;
component C is
	  bm                    : in  bmetric;
	  pathmetricC           : buffer integer range 0 to 1023;
      pm                    : out pmetric);
end component;
component D is
	  bm                    : in  bmetric;
	  pathmetricD           : buffer integer range 0 to 1023;
      pm                    : out pmetric);
end component;
component viterbi_table is
 port(bm                :buffer bmetric;
	  enc_data          :in     std_logic_vector(1 downto 0);
      xor_out           :buffer output_data);
end component;
signal ct: integer range 0 to 20:=0;
begin
--path_calc<=path;
process(xor_out,ct,clock,path,enc_data)
begin
	if(rising_edge(clock)) then
	path_calc<=path;
		ct<=ct+1;
		if(ct=1) then
		xor_out(0)<=enc_data xor "00";
		xor_out(1)<=enc_data xor "11";
		path(2)(14 downto 0)<=path(0)(13 downto 0);
		path(2)(0)<='1';
		for i in 0 to 1 loop
			if (xor_out(0)(i)=1) then
			pm(0)<=pm(0)+1;
			end if;
			if (xor_out(1)(i)=1) then
			pm(2)<=pm(2)+1;
			end if;
		end loop;
		elsif(ct+2) then
		xor_out(4)<=enc_data xor "10";
		xor_out(5)<=enc_data xor "01";
		path(1)(14 downto 1)<=path(2)(13 downto 0);
		path(1)(0)<='0';
		path(3)(14 downto 1)<=path(2)(13 downto 0);
		path(3)(0)<='1';
		path(2)(14 downto 1)<=path(0)(13 downto 0);
		path(2)(0)<='1';
		if ( xor_out(0)(i)='1') then
		pm(0)<=pm(0)+1;
		end if;
		if ( xor_out(1)(i)='1') then
		pm(1)<=pm(1)+1;
		end if;
		if ( xor_out(4)(i)='1') then
		pm(1)<=pm(4)+1;
		end if;
		if ( xor_out(5)(i)='1') then
		pm(5)<=pm(5)+1;
		end if;
		end loop;
		end if;
		viterbi: for ct in 2 to 15 generate
			bm(0)<=pm(0);
			bm(1)<=pm(0);
			bm(2)<=pm(1);
			bm(3)<=pm(1);
			bm(4)<=pm(2);
			bm(5)<=pm(2);
			bm(6)<=pm(3);
			bm(7)<=pm(3);
			Table: Viterbi_table port map(bm,enc_data,xor_out);
			atA: A port map(xor_out,path,bm,pm(0),pm);
			atB: B port map(xor_out,path,bm,pm(1),pm);
			atC: C port map(xor_out,path,bm,pm(2),pm);
			atD: D port map(xor_out,path,bm,pm(3),pm);
		end generate;
		ct<=0;
		end if;
		end if;
end process;
end func;
the code for viterbi_table
library ieee;
library work;
entity viterbi_table is
end viterbi_table;
architecture func of viterbi_table is
signal output:output_data;
begin
output(0)<="00";
output(1)<="11";
output(2)<="11";
output(3)<="00";
output(4)<="10";
output(5)<="01";
output(6)<="01";
output(7)<="10";
process(enc_data,output,xor_out,bm)
begin
for i in 0 to 7 loop
xor_out(i)<=enc_data xor output(i);
	for j in 0 to 1 loop
		if ( xor_out(i)(j)='1') then
   			bm(i)<=bm(i)+1;
		end if;
	end loop;
end loop ;
end process;
end func;
code for A,B,C,D:
library ieee;
library work;
entity A is
	  bm                    : in  bmetric;
      pm                    : out pmetric);
 end A;
architecture func of A is
signal pmetric_calc: metric_calc;
signal path_calc   : statehist_data;
begin
path_calc(0)<=path(0);
path_calc(1)<=path(1);
path_calc(2)<=path(2);
path_calc(3)<=path(3);
process(pmetric_calc,bm,path_calc,pathmetricA)
begin
pmetric_calc(0)<=pathmetricA+bm(0);
pmetric_calc(1)<=pathmetricA+bm(2);
	if (pmetric_calc(0)<pmetric_calc(1)) then
		pathmetricA<=pmetric_calc(0);
		path(0)(14 downto 1)<=path_calc(0)(13 downto 0);
		path(0)(0)<='0';
	elsif(pmetric_calc(0)>pmetric_calc(1)) then
		pathmetricA<=pmetric_calc(1);
		path(0)(14 downto 1)<=path_calc(1)(13 downto 0);
		path(0)(0)<='0';
	end if;
end process;
end func;
library ieee;
library work;
entity B is
	  bm                    : in  bmetric;
      pm                    : out pmetric);
 end B;
architecture func of B is
begin
process(pmetric_calc,bm,path_calc,pathmetricB)
begin
pmetric_calc(0)<=pathmetricB+bm(4);
pmetric_calc(1)<=pathmetricB+bm(6);
		pathmetricB<=pmetric_calc(0);
		path(1)(14 downto 1)<=path_calc(1)(13 downto 0);
		path(1)(0)<='0';
		pathmetricB<=pmetric_calc(1);
		path(1)(0)<='0';
	end if;
end process;
end func;
library ieee;
library work;
entity C is
	  bm                    : in  bmetric;
      pm                    : out pmetric);
 end C;
architecture func of C is
begin
process(pmetric_calc,bm,path_calc,pathmetricC)
begin
pmetric_calc(0)<=pathmetricC+bm(1);
pmetric_calc(1)<=pathmetricC+bm(3);
		pathmetricC<=pmetric_calc(0);
		path(2)(14 downto 1)<=path_calc(2)(13 downto 0);
		path(2)(0)<='1';
		pathmetricC<=pmetric_calc(1);
		path(2)(0)<='1';
	end if;
end process;
end func;
library ieee;
library work;
entity D is
	  bm                    : in  bmetric;
      pm                    : out pmetric);
 end D;
architecture func of D is
begin
process(pmetric_calc,bm,path_calc,pathmetricD)
begin
pmetric_calc(0)<=pathmetricD+bm(5);
pmetric_calc(1)<=pathmetricD+bm(7);
		pathmetricD<=pmetric_calc(0);
		path(3)(14 downto 1)<=path_calc(3)(13 downto 0);
		path(3)(0)<='1';
		pathmetricD<=pmetric_calc(1);
		path(3)(0)<='1';
	end if;
end process;
end func;
data package :
library ieee;
package data_packages is
 type statenew_data  is array(7 downto 0) of std_logic_vector(1 downto 0);
 type statehist_data is array(3 downto 0) of std_logic_vector(14 downto 0);
 type state_data     is array(7 downto 0) of std_logic_vector(1 downto 0);
 type output_data    is array(7 downto 0) of std_logic_vector(1 downto 0);
 type bmetric        is array(7 downto 0) of integer range 0 to 2;
 type pmetric        is array(3 downto 0) of integer range 0 to 1023;
 type metric_calc    is array(1 downto 0) of integer range 0 to 1023;
end;
The errors are as follows
Error (10500): VHDL syntax error at Viterbi_decode.vhd(105) near text "generate"; expecting "loop"
Error (10500): VHDL syntax error at Viterbi_decode.vhd(114) near text "port"; expecting "(", or "'", or "."
Error (10500): VHDL syntax error at Viterbi_decode.vhd(114) near text ";"; expecting ":=", or "<="
Error (10500): VHDL syntax error at Viterbi_decode.vhd(115) near text "port"; expecting "(", or "'", or "."
Error (10500): VHDL syntax error at Viterbi_decode.vhd(115) near text ";"; expecting ":=", or "<="
Error (10500): VHDL syntax error at Viterbi_decode.vhd(116) near text "port"; expecting "(", or "'", or "."
Error (10500): VHDL syntax error at Viterbi_decode.vhd(116) near text ";"; expecting ":=", or "<="
Error (10500): VHDL syntax error at Viterbi_decode.vhd(117) near text "port"; expecting "(", or "'", or "."
Error (10500): VHDL syntax error at Viterbi_decode.vhd(117) near text ";"; expecting ":=", or "<="
Error (10500): VHDL syntax error at Viterbi_decode.vhd(118) near text "port"; expecting "(", or "'", or "."
Error (10500): VHDL syntax error at Viterbi_decode.vhd(118) near text ";"; expecting ":=", or "<="
Error (10500): VHDL syntax error at Viterbi_decode.vhd(122) near text "if"; expecting "process"
In addition to that, I have a query.. is it wrong to use component instantiation inside a process or a conditional loop
Im sorry but its forbidden to use component declarations in processes.
Your blocks A B C D are simple combination logic so i suggest write them as a functions and add them to data_package and then change generic in viterbi_decode to simple loop with function declarations within
There is possibility to use components initiation in conditional loop such as: (exp without a loop)
condition1: if sth = true generate
--possible loop here
component(i): mycomponent port map .....
-- end possible loop here
end generate;
how do i use packages for the task... can i include all the functions i need in the same package? Also, if i write different components one after the other in the viterbi_decode WITHOUT a loop or process, will they execute iteratively (or simply,loop after completing the last component in order) if the component called for has a process satetement checking for rising edge of clock
like for ex:
A:A port map....
B:B port map....
L:L port map....
if the component A has a loop based on rising edge of a clock will it be executed again after the completion of L?
the following is the code i wrote afresh for the same decoding scheme.....
library ieee;
library work;
entity Viterbi_new is
port (clock: in std_logic;
	  --ct: buffer integer range 0 to 16;
	  enc_data: in std_logic_vector(1 downto 0);
	  dec_data: out std_logic_vector(14 downto 0));
end Viterbi_new;
architecture decode of Viterbi_new is
signal metricfinalA: integer range 0 to 30:=1;
signal metricfinalB: integer range 0 to 30:=1;
signal metricfinalC: integer range 0 to 30:=1;
signal metricfinalD: integer range 0 to 30:=1;
signal pathfinalA: std_logic_vector(14 downto 0);
signal pathfinalB: std_logic_vector(14 downto 0);
signal pathfinalC: std_logic_vector(14 downto 0);
signal pathfinalD: std_logic_vector(14 downto 0);
--signal ct:integer range 0 to 16;
signal metricind_A: metricind_data;
signal metricind_B: metricind_data;
signal metricind_C: metricind_data;
signal metricind_D: metricind_data;
signal pathind_A: pathind_data;
signal pathind_B: pathind_data;
signal pathind_C: pathind_data;
signal pathind_D: pathind_data;
signal xorA : xor_data;
signal xorB : xor_data;
signal xorC : xor_data;
signal xorD : xor_data;
signal outA:xor_data;
signal outB:xor_data;
signal outC:xor_data;
signal outD:xor_data;
signal zero:std_logic;
signal pathfinal: std_logic_vector(14 downto 0);
signal metric_decide: integer range 0 to 30;
signal path_finals: pathfinal_data;
signal metricfinals:metricfinal_data;
begin
process(pathfinal,clock,enc_data,xorA,xorB,xorC,xorD,pathind_A,pathind_B,pathind_C,pathind_D,metricind_A,metricind_B,metricind_C,metricind_D,outA,outB,outC,outD)
begin
outA(0)<="00";
outA(1)<="11";
outB(0)<="11";
outB(1)<="00";
outC(0)<="10";
outC(1)<="01";
outD(0)<="01";
outD(1)<="10";
if (rising_edge(clock)) then
	--ct<=ct+1;
for j in 0 to 15 loop
	--ct<=ct+1;
	pathind_A(0)(14 downto 1)<=pathfinalA(13 downto 0);
	pathind_A(1)(14 downto 1)<=pathfinalB(13 downto 0);
	pathind_B(0)(14 downto 1)<=pathfinalC(13 downto 0);
	pathind_B(1)(14 downto 1)<=pathfinalD(13 downto 0);
	pathind_C(0)(14 downto 1)<=pathfinalA(13 downto 0);
	pathind_C(1)(14 downto 1)<=pathfinalB(13 downto 0);
	pathind_D(0)(14 downto 1)<=pathfinalC(13 downto 0);
	pathind_D(1)(14 downto 1)<=pathfinalD(13 downto 0);
	pathind_A(0)(0)<='0';
	pathind_A(1)(0)<='0';
	pathind_B(0)(0)<='0';
	pathind_B(1)(0)<='0';
	pathind_C(0)(0)<='1';
	pathind_C(1)(0)<='1';
	pathind_D(0)(0)<='1';
	pathind_D(1)(0)<='1';
			xorA(i)<=outA(i) xor enc_data;
			xorB(i)<=outB(i) xor enc_data;
			xorC(i)<=outC(i) xor enc_data;
			xorD(i)<=outD(i) xor enc_data;
		end loop;
 			if(xorA(0)(i)<='1') then
			metricind_A(0)<=metricfinalA+1;
			end if;
			if(xorA(1)(i)<='1') then
			metricind_A(1)<=metricfinalB+1;
			end if;
			if(xorB(0)(i)<='1') then
			metricind_B(0)<=metricfinalC+1;
			end if;
			if(xorB(1)(i)<='1') then
			metricind_B(1)<=metricfinalD+1;
			end if;
			if(xorC(0)(i)<='1') then
			metricind_C(0)<=metricfinalA+1;
			end if;
			if(xorC(1)(i)<='1') then
			metricind_C(1)<=metricfinalB+1;
			end if;
			if(xorD(0)(i)<='1') then
			metricind_D(0)<=metricfinalC+1;
			end if;
			if(xorD(1)(i)<='1') then
			metricind_D(1)<=metricfinalD+1;
			end if;
		end loop;
		if(metricind_A(0)<metricind_A(1)) then
		pathfinalA<=pathind_A(0);
		metricfinalA<=metricind_A(0);
		elsif(metricind_A(0)>metricind_A(1)) then
		pathfinalA<=pathind_A(1);
		metricfinalA<=metricind_A(1);
		end if;
		if(metricind_B(0)<metricind_B(1)) then
		pathfinalB<=pathind_B(0);
		metricfinalB<=metricind_B(0);
		elsif(metricind_B(0)>metricind_B(1)) then
		pathfinalB<=pathind_B(1);
		metricfinalB<=metricind_B(1);
		end if;
		if(metricind_C(0)<metricind_C(1)) then
		pathfinalC<=pathind_C(0);
		metricfinalC<=metricind_C(0);
		elsif(metricind_C(0)>metricind_C(1)) then
		pathfinalC<=pathind_C(1);
		metricfinalC<=metricind_C(1);
		end if;
		if(metricind_D(0)<metricind_D(1)) then
		pathfinalD<=pathind_D(0);
		metricfinalD<=metricind_D(0);
		elsif(metricind_D(0)>metricind_D(1)) then
		pathfinalD<=pathind_D(1);
		metricfinalD<=metricind_D(1);
		end if;
		metricfinals(0)<=metricfinalA;
		metricfinals(1)<=metricfinalB;
		metricfinals(2)<=metricfinalC;
		metricfinals(3)<=metricfinalD;
		path_finals(0)<=pathfinalA;
		path_finals(1)<=pathfinalB;
		path_finals(2)<=pathfinalC;
		path_finals(3)<=pathfinalD;
end loop;
--if (ct>15) then
	pathfinal<=path_finals(0);
	metric_decide<=metricfinals(0);
	for i in 1 to 3 loop
	if(metricfinals(i)>metric_decide) then
	metricfinals(i)<=metric_decide;
	pathfinal<=path_finals(i);
	end if;
	end loop;
--end if;
end if;
dec_data<=pathfinal;
end process;
--dec_data<=pathfinal;
end decode;
data_packages_2:
library ieee;
type pathfinal_data   is array (3 downto 0) of std_logic_vector(14 downto 0);
type xor_data         is array (1 downto 0) of std_logic_vector(1 downto 0);
type metricind_data   is array (1 downto 0) of integer range 0 to 30;
type metricfinal_data is array (3 downto 0) of integer range 0 to 30;
type pathind_data     is array (1 downto 0) of std_logic_vector(14 downto 0);
end;
the following are the warnings im receiving after compilation
Warning: Reduced register "pathind_D[0][0]" with stuck data_in port to stuck value VCC
Warning: Reduced register "pathind_D[1][0]" with stuck data_in port to stuck value VCC
Warning: Reduced register "pathind_C[0][0]" with stuck data_in port to stuck value VCC
Warning: Reduced register "pathind_C[1][0]" with stuck data_in port to stuck value VCC
Warning: Reduced register "pathind_B[0][0]" with stuck data_in port to stuck value GND
Warning: Reduced register "pathind_B[1][0]" with stuck data_in port to stuck value GND
Warning: Reduced register "pathind_A[0][0]" with stuck data_in port to stuck value GND
Warning: Reduced register "pathind_A[1][0]" with stuck data_in port to stuck value GND
Warning: Reduced register "pathfinalA[0]" with stuck data_in port to stuck value GND
Warning: Reduced register "pathfinalB[0]" with stuck data_in port to stuck value GND
Warning: Reduced register "pathfinalC[0]" with stuck data_in port to stuck value VCC
Warning: Reduced register "pathfinalD[0]" with stuck data_in port to stuck value VCC
Warning: Reduced register "pathind_A[1][1]" with stuck data_in port to stuck value GND
Warning: Reduced register "pathind_A[0][1]" with stuck data_in port to stuck value GND
Warning: Reduced register "pathind_B[1][1]" with stuck data_in port to stuck value VCC
Warning: Reduced register "pathind_B[0][1]" with stuck data_in port to stuck value VCC
Warning: Reduced register "pathind_C[1][1]" with stuck data_in port to stuck value GND
Warning: Reduced register "pathind_C[0][1]" with stuck data_in port to stuck value GND
Warning: Reduced register "pathind_D[1][1]" with stuck data_in port to stuck value VCC
Warning: Reduced register "pathind_D[0][1]" with stuck data_in port to stuck value VCC
Warning: Reduced register "path_finals[0][0]" with stuck data_in port to stuck value GND
Warning: Reduced register "path_finals[1][0]" with stuck data_in port to stuck value GND
Warning: Reduced register "path_finals[2][0]" with stuck data_in port to stuck value VCC
Warning: Reduced register "path_finals[3][0]" with stuck data_in port to stuck value VCC
Warning: Reduced register "pathfinalA[1]" with stuck data_in port to stuck value GND
Warning: Reduced register "pathfinalB[1]" with stuck data_in port to stuck value VCC
Warning: Reduced register "pathfinalC[1]" with stuck data_in port to stuck value GND
Warning: Reduced register "pathfinalD[1]" with stuck data_in port to stuck value VCC
Warning: Reduced register "pathind_A[1][2]" with stuck data_in port to stuck value VCC
Warning: Reduced register "pathind_A[0][2]" with stuck data_in port to stuck value GND
Warning: Reduced register "pathind_B[1][2]" with stuck data_in port to stuck value VCC
Warning: Reduced register "pathind_B[0][2]" with stuck data_in port to stuck value GND
Warning: Reduced register "pathind_C[1][2]" with stuck data_in port to stuck value VCC
Warning: Reduced register "pathind_C[0][2]" with stuck data_in port to stuck value GND
Warning: Reduced register "pathind_D[1][2]" with stuck data_in port to stuck value VCC
Warning: Reduced register "pathind_D[0][2]" with stuck data_in port to stuck value GND
Warning: Reduced register "path_finals[0][1]" with stuck data_in port to stuck value GND
Warning: Reduced register "path_finals[1][1]" with stuck data_in port to stuck value VCC
Warning: Reduced register "path_finals[2][1]" with stuck data_in port to stuck value GND
Warning: Reduced register "path_finals[3][1]" with stuck data_in port to stuck value VCC
Warning: Reduced register "metricfinalD[4]" with stuck data_in port to stuck value GND
Warning: Reduced register "metricfinalD[3]" with stuck data_in port to stuck value GND
Warning: Reduced register "metricfinalD[2]" with stuck data_in port to stuck value GND
Warning: Reduced register "metricfinalD[1]" with stuck data_in port to stuck value GND
Warning: Reduced register "metricfinalD[0]" with stuck data_in port to stuck value VCC
Warning: Reduced register "pathfinalD[2]" with stuck data_in port to stuck value GND
Warning: Reduced register "pathfinalD[3]" with stuck data_in port to stuck value GND
Warning: Reduced register "pathfinalD[4]" with stuck data_in port to stuck value GND
Warning: Reduced register "pathfinalD[5]" with stuck data_in port to stuck value GND
Warning: Reduced register "pathfinalD[6]" with stuck data_in port to stuck value GND
Warning: Reduced register "pathfinalD[7]" with stuck data_in port to stuck value GND
Warning: Reduced register "pathfinalD[8]" with stuck data_in port to stuck value GND
Warning: Reduced register "pathfinalD[9]" with stuck data_in port to stuck value GND
Warning: Reduced register "pathfinalD[10]" with stuck data_in port to stuck value GND
Warning: Reduced register "pathfinalD[11]" with stuck data_in port to stuck value GND
Warning: Reduced register "pathfinalD[12]" with stuck data_in port to stuck value GND
Warning: Reduced register "pathfinalD[13]" with stuck data_in port to stuck value GND
Warning: Reduced register "pathfinalD[14]" with stuck data_in port to stuck value GND
Warning: Reduced register "path_finals[3][2]" with stuck data_in port to stuck value GND
Warning: Reduced register "path_finals[3][3]" with stuck data_in port to stuck value GND
Warning: Reduced register "path_finals[3][4]" with stuck data_in port to stuck value GND
Warning: Reduced register "path_finals[3][5]" with stuck data_in port to stuck value GND
Warning: Reduced register "path_finals[3][6]" with stuck data_in port to stuck value GND
Warning: Reduced register "path_finals[3][7]" with stuck data_in port to stuck value GND
Warning: Reduced register "path_finals[3][8]" with stuck data_in port to stuck value GND
Warning: Reduced register "path_finals[3][9]" with stuck data_in port to stuck value GND
Warning: Reduced register "path_finals[3][10]" with stuck data_in port to stuck value GND
Warning: Reduced register "path_finals[3][11]" with stuck data_in port to stuck value GND
Warning: Reduced register "path_finals[3][12]" with stuck data_in port to stuck value GND
Warning: Reduced register "path_finals[3][13]" with stuck data_in port to stuck value GND
Warning: Reduced register "path_finals[3][14]" with stuck data_in port to stuck value GND
Warning: Reduced register "metricfinals[0][4]" with stuck data_in port to stuck value GND
Warning: Reduced register "metricfinals[0][3]" with stuck data_in port to stuck value GND
Warning: Reduced register "metricfinals[0][2]" with stuck data_in port to stuck value GND
Warning: Reduced register "metricfinals[0][1]" with stuck data_in port to stuck value GND
Warning: Reduced register "pathfinal[2]" with stuck data_in port to stuck value GND
Warning: Reduced register "pathfinal[3]" with stuck data_in port to stuck value GND
Warning: Reduced register "pathfinal[4]" with stuck data_in port to stuck value GND
Warning: Reduced register "pathfinal[5]" with stuck data_in port to stuck value GND
Warning: Reduced register "pathfinal[6]" with stuck data_in port to stuck value GND
Warning: Reduced register "pathfinal[7]" with stuck data_in port to stuck value GND
Warning: Reduced register "pathfinal[8]" with stuck data_in port to stuck value GND
Warning: Reduced register "pathfinal[9]" with stuck data_in port to stuck value GND
Warning: Reduced register "pathfinal[10]" with stuck data_in port to stuck value GND
Warning: Reduced register "pathfinal[11]" with stuck data_in port to stuck value GND
Warning: Reduced register "pathfinal[12]" with stuck data_in port to stuck value GND
Warning: Reduced register "pathfinal[13]" with stuck data_in port to stuck value GND
Warning: Reduced register "pathfinal[14]" with stuck data_in port to stuck value GND
Warning: Reduced register "metric_decide[4]" with stuck data_in port to stuck value GND
Warning: Reduced register "metric_decide[3]" with stuck data_in port to stuck value GND
Warning: Reduced register "metric_decide[2]" with stuck data_in port to stuck value GND
Warning: Reduced register "metric_decide[1]" with stuck data_in port to stuck value GND
Warning: Reduced register "metricfinals[3][4]" with stuck data_in port to stuck value GND
Warning: Reduced register "metricfinals[3][3]" with stuck data_in port to stuck value GND
Warning: Reduced register "metricfinals[3][2]" with stuck data_in port to stuck value GND
Warning: Reduced register "metricfinals[3][1]" with stuck data_in port to stuck value GND
Warning: Reduced register "metricfinals[2][4]" with stuck data_in port to stuck value GND
Warning: Reduced register "metricfinals[2][3]" with stuck data_in port to stuck value GND
Warning: Reduced register "metricfinals[2][2]" with stuck data_in port to stuck value GND
Warning: Reduced register "metricfinals[2][1]" with stuck data_in port to stuck value GND
Warning: Reduced register "metricfinals[1][4]" with stuck data_in port to stuck value GND
Warning: Reduced register "metricfinals[1][3]" with stuck data_in port to stuck value GND
Warning: Reduced register "metricfinals[1][2]" with stuck data_in port to stuck value GND
Warning: Reduced register "metricfinals[1][1]" with stuck data_in port to stuck value GND
Warning: Output pins are stuck at VCC or GND
Warning: Pin "dec_data[2]" stuck at GND
Warning: Pin "dec_data[3]" stuck at GND
Warning: Pin "dec_data[4]" stuck at GND
Warning: Pin "dec_data[5]" stuck at GND
Warning: Pin "dec_data[6]" stuck at GND
Warning: Pin "dec_data[7]" stuck at GND
Warning: Pin "dec_data[8]" stuck at GND
Warning: Pin "dec_data[9]" stuck at GND
Warning: Pin "dec_data[10]" stuck at GND
Warning: Pin "dec_data[11]" stuck at GND
Warning: Pin "dec_data[12]" stuck at GND
Warning: Pin "dec_data[13]" stuck at GND
Warning: Pin "dec_data[14]" stuck at GND
Warning: Design contains 2 input pin(s) that do not drive logic
Warning: No output dependent on input pin "enc_data[0]"
Warning: No output dependent on input pin "enc_data[1]"
please help me solve the issue
It has determined that those registers are stuck at 0 or 1, hence the warning about removal. Its probably because is clock, clock enable or reset is stuck at '1' or '0'. Have you testbenched this code?
A little weird that you perfectly know how to write good (sort of) VHDL, and don't know how to build a test bench.
Take a book about VHDL, open it up at chapter 9 or 10 - test benches, define your stimuli, that's it.
Are u talking about the simulator, i mean vector waveform file? In that case, I dop know what tht is and have tried it for the program... But to no avail
Also, is it possible to get a newer version of quartus. I mean for free..... And if i do, will I get to configure a FPGA with tht version itself?
It depends what your chip is. If its a cyclone 1, you'll probably have to stick with the version you got.
mine is altera 7160slc.... should i stick to my version or is better one preferred... please post link for the download page, and please answer my other question , "Are u talking about the simulator, i mean vector waveform file? In that case, I dop know what tht is and have tried it for the program... But to no avail". thanks in advance
The downloads are on the altera website. Ill let you go look yourself. THe 7160slc is a very old Max7000 device. Support for it was probably dropped in quartus 9.1.
When we talk about simulation, usually that is performed in a 3rd party RTL simulator (like modelsim) using a testbench you created yourself. waveform files are not a very powerful tool.
You might be able to use an old version of the web edition, but I dont know. It would be best to stick with the version you have if it works.
