I would like to set my custom hotkey in Cadence Virtuoso. How could I do so? For example, to zoom in, just press ctrl-z or any key I prefer. Any example written in SKILL??
It contains the default hotkeys definition. You can make a local copy of it in your project directory or home directory. Then you can edit it as you wish.
Then you'll need a way to load this file. If you have write permissions on your cadence installation hierarchy, I'd recommend you to do the following:
This will enable default hotkeys whenever and wherever you start cadence tools. Then you can make a copy of leBindKeys.il file in your homedir and it will take precedence over the default one when your start cadence tools.
If you don't have permission to modify the installation hierarchy, your can make your own .cdsinit file using default one as a template and place it in your homedir and load a customized leBindKeys.il from it using the load() function.
Look through the supplied default initialization files and all the details should become clear to you.
hey, first of all great job on edaboard, thanks a lot for all your help guys!
I'm a cadence beginner and I'm working on a basic inverter for a start- my keyboard shortcuts aren't working either.
I tried copying the bindkeys.il file into my home directory, and common_bindkeys.il.. yet it doesnt work.. someone help me pls !
Do you have .cdsinit file in your home directory?
If no, please create one.
And put the following in this .cdsinit:
load("your_home/your_hotkey_file.il")
hey Will, thanks for the quick response!
nope, that dint work. I did have a .cdsinit in my home directory. inserted that bit of code, but that doesn't work yet.
