Livingston
Full Member level 2
- Joined
- Nov 26, 2007
- Messages
- 129
- Helped
- 3
- Reputation
- 6
- Reaction score
- 1
- Trophy points
- 1,298
- Location
- Chennai-India
- Activity points
- 2,104
I have a problem with virtual terminal of proteus 8. I wrote a code in mikroc PRO for pic. The code was to recieve data at 19200 baud rate and parse the string so that i read 8 bytes. I have used a circular buffer, you can find how the circular buffer works from this link https://leap-embedded-system.com/?p=79 . i have used an interrupt based program since i shouldnt miss any received data. The problem comes when i test this with the virtual terminal of proteus. i give input to my pic from virtual terminal and observe the ouput through another virtual terminal. When i give input i pasted 6 strings and the virtual terminal just transmits 4 and a half strings and i am getting 4 outputs. when i paste only 4 strings or less to the terminal i get outputs for all the strings sent. Also to mention when i work at baud rates of 4800 or 2400 i get outputs for any number of strings.
i tested this for a simple program which uses inteerupts to echo a character, even then the virtual terminal limits the numebr of chars entered by stopping somewhere in the middle.
Is this a problem of virtual terminal ? i should strictly follow a baud rate of 19200!
I am pasting the code below ,
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 char rxchar; //variable for storing data from UART int i = 0, flag = 0,count=0,j=0,msgs=0; // array counter and flag to write once the desired pattern is read char buf[1025]; // array to store the received charaters char *rc_ptr,*tx_ptr; char output[15],testbuf[2]; //array to write data to tx enum{WAIT_FOR_1C,WAIT_FOR_6bytes,RECEIVING,MSG_RCVD} state=WAIT_FOR_1C; /*******************************************************************************/ void interrupt () { if (PIR1.RCIF) { // test the interrupt for uart rx rxchar = UART1_Read(); //read a byte from UART switch(state){ case WAIT_FOR_1C: //wait till 1C is arrived if(j>1){ j=1; testbuf[0]=testbuf[1]; testbuf[j]=rxchar; j++; if(strstr(testbuf,"1C")!=0){ j=0; state = WAIT_FOR_6bytes; } } testbuf[j]=rxchar; j++; if(strstr(testbuf,"1C")!=0){ j=0; state = WAIT_FOR_6bytes; } break; case WAIT_FOR_6bytes: i++; if(i>=6){ i=0; state=RECEIVING; } break; case RECEIVING: if(count==1024){ count=0; rc_ptr=buf; } *rc_ptr=rxchar; rc_ptr++; count++; if(count%8==0){ msgs=msgs+1; state=WAIT_FOR_1C ; } break; } // end interrupt } } /******************************************************************************/ void main () { ANSELA=0; ANSELC=0; TRISA=0; TRISC=0xC0; LATA=0x00; INTCON.GIE = 1; //enable global interrupt INTCON.PEIE = 1; PIE1.RCIE = 1; //enable receive interrupt. UART1_Init(4800); rc_ptr=buf; tx_ptr=buf; while(1) { // Begin endless loop // This section is where you tell the program what to do with the data once it // has all arrived while(msgs!=0){ //read all the messages strncpy(output,tx_ptr,8); //copy 8 bytes from the buffer Uart1_Write_Text("DATA:"); Uart1_Write_Text(output); Uart1_Write(13); //new line char tx_ptr=tx_ptr+8; // increment the tr_ptr to the next 8 bytes if( tx_ptr - buf ==1024){ //if tx_ptr reaches the end of buffer loop back to beginning tx_ptr = buf; } msgs=msgs-1; } } // end while } // end main
