VHDL - Writing a Value to Register
johnmroberts
Newbie level 2
Newbie level 2
I have an FPGA (Cyclone II) with four push buttons - the two left most ones should cycle up and down the 16 registers, while the two right most ones should increment and decrement the value stored in this register. Here is my attempt at the code to do this:
entity raminfr is --inferring the RAM here
port (
clk : in std_logic;
we : in std_logic;
a : in unsigned(3 downto 0);
di : in unsigned(7 downto 0);
do : out unsigned(7 downto 0)
end raminfr;
architecture rtl of raminfr is
type ram_type is array (0 to 15) of unsigned(7 downto 0);
signal RAM : ram_type;
signal read_a : unsigned(3 downto 0);
begin
U1: entity work.lab1 port map ( --ERROR ON THIS LINE
register_counter => a,
value_counter => di
process (clk)
begin
if rising_edge(clk) then
if we = '1' then
RAM(to_integer(a)) <= di;
end if;
read_a <= a;
end if;
end process;
do <= RAM(to_integer(read_a));
end rtl;
--lab1 starts here
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity lab1 is
port(
clock : in std_logic;
key : in std_logic_vector(3 downto 0);
value_counter : out unsigned(7 downto 0) ; --value to be written to register
register_counter : out unsigned(3 downto 0) --register to write value to
end lab1;
architecture up_and_down of lab1 is --actual button logic here
begin
process(clock)
begin
if rising_edge(clock) then
if (key(3)='0' and key(2)='0' and key(1)='1' and key(0)='0') then
value_counter <= value_counter + "1";
elsif (key(3)='0' and key(2)='0' and key(1)='0' and key(0)='1') then
value_counter <= value_counter - "1";
elsif (key(3)='1' and key(2)='0' and key(1)='0' and key(0)='0') then
register_counter<= register_counter + "1";
elsif (key(3)='0' and key(2)='1' and key(1)='0' and key(0)='0') then
register_counter<= register_counter - "1";
end if;
end if;
end process;
end architecture up_and_down;
I get the error `Error (10577): VHDL error at DE2_TOP.vhd(312): actual port "a" of mode "in" cannot be associated with formal port "register_counter" of mode "out"`on the line indicated above. It is obvious this is not how I would go about doing what I want to do. Can someone shed some light on this?
VHDL - Writing To Registers
I want to use four push buttons as inputs and three seven-segment LED displays as outputs. Two push buttons should step up and down through the sixteen RAM locations; the other two should increment and decrement the contents of the currently-displayed memory location. One seven segment display should show the current address (0–F), and two others should display the contents of that location in hexadecimal (00–FF). This is my code to attempt to do this (I haven't implemented the display yet):
library ieee;
entity raminfr is
port (
clk : in std_logic;
we : in std_logic;
end raminfr;
signal a : unsigned(3 downto 0);
signal di : unsigned(7 downto 0);
signal clock : std_logic;
signal key : std_logic_vector(3 downto 0);
begin
clock =>clock,
key => key,
value_counter => di
process (clk)
begin
if we = '1' then
end if;
read_a <= a;
end if;
end process;
end rtl;
library ieee;
entity lab1 is
port(
value_counter : buffer unsigned(7 downto 0) ;
register_counter : buffer unsigned(3 downto 0)
end lab1;
signal value_in_ram : unsigned(7 downto 0);
signal clk : std_logic;
signal we : std_logic;
begin
U1: entity work.raminfr port map (
do=>value_in_ram,
clk=>clk,
we=>we
process(clock, value_counter, register_counter)
begin
value_counter <= value_in_ram;
end if;
end if;
end process;
When I try to compile this, I get the following errors repeating over and over:
Error (12051): Project too complex: hierarchy path is too long
Error (12052): Entity "lab1" is instantiated by entity "raminfr"
Error (12052): Entity "raminfr" is instantiated by entity "lab1"
This is obviously due to the fact that I have port mapped each entity in the other, but I don't know any other way to accomplish what I want to accomplish. Can somebody suggest alternatives?
Do you understand that the HDL in VHDL stands for Hardware Description Language? What you've written can't be implemented in HW.
You have an infinite instantiation of the raminfr and lab1. You need a top level file, that has BOTH of these entities instantiated.
Draw a circuit of what you want then write the VHDL code that represents that circuit.
