VHDL SPI interface two FPGA
ayanmosh
Newbie level 1
Newbie level 1
Hello,
This forum has been really helpful, I have gone really far into my project but I have two small little problems.
Details about my project:
I need to use SPI to connect two FPGA's (BASYS 2 SPARTAN 3e). Everything works except I have two problems:
Here is a youtube video of my problem:
https://www.youtube.com/watch?v=NMU0-LgUMZc
If you see in this video, when I press btn1, it sends data to the slave, but the problem is that I need to "catch" it on the right time, in order to get a mirror image of the master.
Here is my master code:
Code VHDL - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
library ieee ;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
use IEEE.numeric_std.all;
entity fpga is
port(
clk : in std_logic;
btn : in std_logic;
sclk : out std_logic;
mosi : out std_logic;
ss : out std_logic;
input : in std_logic_vector (7 downto 0);
seg : out std_logic_vector (6 downto 0);
an : out std_logic_vector (3 downto 0)
end fpga;
architecture anderson of fpga is
component decoder
port(
input : in std_logic_vector(3 downto 0);
seg : out std_logic_vector(6 downto 0)
end component;
signal counter : std_logic_vector(18 downto 0);
signal sel : std_logic;
signal an1, an2 : std_logic_vector(6 downto 0);
type state_type is (s0,s1,s2,s3,s4,s5,s6,s7,s8,s9);
signal next_state, current_state: state_type;
signal count_reg, next_count : std_logic_vector (7 downto 0);
signal data: std_logic_vector(7 downto 0);
signal input_read: std_logic_vector(7 downto 0);
begin
seg_one : decoder
port map(
input => input(7 downto 4),
seg => an1
seg_two : decoder
port map(
input => input(3 downto 0),
seg => an2
sclk <= clk after 50 ns;
process (btn)
begin
case current_state is
when s0 => -- S0 no data sent
if btn = '1' then
ss<='0';
mosi<='0';
data <= input;
next_state <= s1;
else
next_state<=s0;
end if;
when s1 => mosi <= data(0);
next_state <= s2;
when s2 => mosi <= data(1);
next_state <= s3;
when s3 => mosi <= data(2);
next_state <= s4;
when s4 => mosi <= data(3);
next_state <= s5;
when s5 => mosi <= data(4);
next_state <= s6;
when s6 => mosi <= data(5);
next_state <= s7;
when s7 => mosi <= data(6);
next_state <= s8;
when s8 => mosi <= data(7);
next_state <= s0;
when others => mosi <='0';
end case;
end process;
process (clk)
begin
if falling_edge (clk)
then
current_state<= next_state;
end if;
end process;
-- Combinational Logic
sel <= counter(16);
process(sel)
begin
case sel is
when '0' => an <= "1110"; seg <= an2;
when '1' => an <= "1101"; seg <= an1;
when others => an <= "1111";
end case;
end process;
process(clk)
begin
if rising_edge(clk) then
counter <= counter + 1;
end if;
end process;
end;
And here is my slave code
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
library ieee ;
entity fpga is
port(
clk : in std_logic;
mosi : in std_logic;
ss : in std_logic;
end fpga;
component decoder
port(
input : in STD_LOGIC_VECTOR(3 downto 0);
seg : out STD_LOGIC_VECTOR(6 downto 0));
end component;
signal counter : std_logic_vector(25 downto 0):=(others => '0');
signal an1 : std_logic_vector(3 downto 0);
signal an2 : std_logic_vector(3 downto 0);
type state_type is (s0,s1,s2,s3,s4,s5,s6,s7,s8);
signal data1: std_logic_vector(3 downto 0);
signal data2: std_logic_vector(3 downto 0);
signal seg1 : std_logic_vector(6 downto 0);
signal seg2 : std_logic_vector(6 downto 0);
signal data_reg : std_logic_vector(7 downto 0):="11111111";
begin
Label1 : decoder
port map(
input => data(7 downto 4),
seg => seg1
Label2 : decoder
port map(
input => data(3 downto 0),
seg => seg2
process (ss)
begin
when s0 =>
if (ss='1') then
next_state <=s1;
else next_state <=s0;
end if;
when s1 => data_reg(0) <= mosi;
next_state <= s2;
when s2 => data_reg(1) <= mosi;
next_state <= s3;
when s3 => data_reg(2) <= mosi;
next_state <= s4;
when s4 => data_reg(3) <= mosi;
next_state <= s5;
when s5 => data_reg(4) <= mosi;
next_state <= s6;
when s6 => data_reg(5) <= mosi;
next_state <= s7;
when s7 => data_reg(6) <= mosi;
next_state <= s8;
when s8 => data_reg(7) <= mosi;
next_state <= s0;
end case;
end process;
data <= data_reg(7 downto 0);
data1 <= data(7 downto 4);
data2 <= data(3 downto 0);
process (counter(15))--- flips the an's so they are both on
begin
case counter(15) is
when '0' => seg <= seg2; an <= "1110";--digit0
when '1' => seg <= seg1; an <= "1101";--digit1
when others => seg <= "1111111"; an <= "1111"; --uhoh
end case;
end process; --------------------------------------------
process(clk) --- clock increases the timer
begin
if (rising_edge(clk)) then
counter <= counter + '1';
current_state <= next_state;
end if;
end process;
end;
The main problem that I am trying to solve is that when I press the button on the master fpga, the display on the slave should match the master's, but this is only working if I "catch" the right signal.
I think my problem is that I don't know how to use the sclk signal. Since I am not even using it on the slave....
Any help please?
