ghattasak
Member level 1
- Joined
- Dec 31, 2012
- Messages
- 33
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Activity points
- 1,595
hello i am having a problem with the vhdl code i have tried assigning all wires to a value but couldnt solve the latche error
can anyone help me and clarfiy the problem? and how can it be solved?
WARNING:Xst:737 - Found 1-bit latch for signal <ctr_rst>. Latches may be generated from incomplete case or if statements. We do not recommend the use of latches in FPGA/CPLD designs, as they may lead to timing problems.
WARNING:Xst:737 - Found 1-bit latch for signal <ldata>. Latches may be generated from incomplete case or if statements. We do not recommend the use of latches in FPGA/CPLD designs, as they may lead to timing problems.
WARNING:Xst:737 - Found 1-bit latch for signal <startsort>. Latches may be generated from incomplete case or if statements. We do not recommend the use of latches in FPGA/CPLD designs, as they may lead to timing problems.
here is my statemachin:
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 ----------------------------------------------------------------- clocked_proc : PROCESS ( clk, reset ) ----------------------------------------------------------------- BEGIN IF (reset = '1') THEN current_state <= s0; ELSIF (clk'EVENT AND clk = '1') THEN current_state <= next_state; END IF; END PROCESS clocked_proc; ----------------------------------------------------------------- nextstate_proc : PROCESS ( current_state, done_load, wr_d ) ----------------------------------------------------------------- BEGIN CASE current_state IS WHEN s0 => IF (wr_d = '0') THEN next_state <= s0; ELSIF (wr_d = '1') THEN next_state <= s1; ELSE next_state <= s0; END IF; WHEN s1 => IF (done_load = '0') THEN next_state <= s1; ELSIF (done_load = '1') THEN next_state <= s2; ELSE next_state <= s1; END IF; WHEN s2 => next_state <= s2; WHEN OTHERS => next_state <= s0; END CASE; END PROCESS nextstate_proc; ----------------------------------------------------------------- output_proc : PROCESS ( current_state, done_load, wr_d, startsort,ldata,ctr_rst ) ----------------------------------------------------------------- BEGIN -- Combined Actions CASE current_state IS WHEN s0 => ldata <= '0' ; sver_en <='1'; startsort <='0'; ctr_rst <= '0'; IF (wr_d = '0') THEN sver_en <= '1' ; startsort <= '0' ; ldata <= '0'; ctr_rst <='0'; ELSIF (wr_d = '1') THEN ldata<= '1'; sver_en <= '1' ; startsort <= '0' ; ctr_rst <='0'; END IF; WHEN s1 => ldata <= '1'; sver_en <= '1' ; startsort <= '0' ; ctr_rst <='0'; IF (done_load = '0') THEN sver_en<= '1' ; startsort <= '0' ; ldata <= '1'; ctr_rst <='0'; ELSIF (done_load = '1') THEN ldata <= '0' ; ctr_rst <= '1'; sver_en <= '1' ; startsort <= '0' ; END IF; WHEN s2 => startsort<= '1'; sver_en<= '1'; ldata <= '0'; ctr_rst <= '0'; WHEN OTHERS => NULL; END CASE; END PROCESS output_proc;
