MRLL
Newbie level 2
I've only been using VHDL for a few months now, and i'm currently working on a RAM module in which the contents of the memory are initially loaded from a file. The module has 5 address lines, 8-birectional data lines, an active low enable, and a read/write select input.
At the moment, i've got to a stage were some sort of value seems to be read from the text value, however, the output always displays the last value in my 32 value, 8-bit array. This would suggest there's a problem with the addressing, but i can't seem to find the issue. Below is my code:
Any help would be greatly appreciated.
Thanks.
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.numeric_std.all;
use std.textio.all;
use ieee.std_logic_textio.all;
use ieee.std_logic_unsigned.all;
entity memory is
port( enable :in std_logic;
RW :in std_logic;
addr :in std_logic_vector(4 downto 0);
data :inout std_logic_vector(7 downto 0)
end memory;
architecture behaviour1 of memory is
signal data_out :std_logic_vector (7 downto 0);
type ram_type is array (0 to 31) of std_logic_vector(7 downto 0);
signal temp_ram: ram_type; -- internal version of ram
begin
-- Tri-State Buffer control
data <= data_out when (enable = '1') else (others=>'Z');
-- Memory Write Block
process (RW, enable)
begin
if RW = '1' and enable = '0' then
temp_ram(conv_integer(addr)) <= data;
end if;
end process;
-- Memory Read Block
begin
if RW = '0' and enable = '0' then
data_out <= temp_ram(conv_integer(addr));
end if;
end process;
end behaviour1;
entity memory_testbench is
end memory_testbench;
architecture testbench_1 of memory_testbench is
file loaddata: text;
-- signals
signal t_enable :std_logic := '0';
signal t_RW :std_logic := '0';
signal t_data :std_logic_vector(7 downto 0);
signal t_wrdata :std_logic_vector(7 downto 0);
signal t_redata :std_logic_vector(7 downto 0);
signal t_addr :std_logic_vector(4 downto 0);
-- components
component memory
port (
enable : in std_logic;
RW : in std_logic;
addr : in std_logic_vector(4 downto 0);
data : inout std_logic_vector(7 downto 0)
end component;
begin
-- Device under test: memory
dut_1 : memory
port map (
enable => t_enable ,
RW => t_RW ,
addr => t_addr ,
data => t_data);
-- Test stimulus
t_data <= t_wrdata when t_RW='1' and t_enable='0';
t_redata <= t_data when t_RW='0' and t_enable='0';
vectors : process
variable advalue: std_logic_vector(7 downto 0);
variable adline: line;
begin
file_open(loaddata,"C:\Users\Luke\Documents\loaddata.txt",read_mode);
while not endfile(loaddata) loop
readline(loaddata,adline);
read(adline,advalue);
end loop;
t_enable <= '0';
t_RW <= '1';
t_addr <= (t_addr'range => '0');
t_wrdata <= advalue;
wait for 100 ns;
t_enable <= '0';
t_RW <= '0';
t_addr <= t_addr + '1';
wait for 100 ns;
t_enable <= '0';
t_RW <= '1';
wait for 100 ns;
t_enable <= '1';
t_RW <= '1';
wait for 100 ns;
wait;
end process vectors;
-- writes to standard output
results_to_screen: process (t_RW, t_enable, t_addr, t_data)
variable Results : line;
variable qi : integer;
begin
report "Signal t_data is " & t_RW'image(t_RW) & " at time " & time'image(now);
write(Results,Now);
write(Results,' ');
write(Results,t_enable);
write(Results,t_RW);
write(Results,t_addr);
write(Results,t_data);
write(Results,' ');
writeline(output,Results);
end process results_to_screen;
end testbench_1;
Thanks.
