Register Log in
VHDL errror for real, std_logic_vector for sine value in DDS
sangitacp93
Newbie
I am trying to generate sine value for DDS, but I have error during synthesis. I have included ''ieee.math_real.all''
Error: [Synth 8-2778] type error near sin ; expected type std_logic_vector ["C:/Users/Sangita.POKHREL/Switches_led/Switches_led.srcs/sources_1/new/top.v":50]
[Synth 8-1731] cannot convert type real to type std_logic_vector ["C:/Users/Sangita.POKHREL/Switches_led/Switches_led.srcs/sources_1/new/top.v":52]
The code snippet is as below:
-- generate sine value
function init_lut_sin return t_lut_sin is
variable return_lut : t_lut_sin:=(others=>(others=>'0'));
variable v_tstep : real :=0.0;
variable v_qsine_sgn : std_logic_vector(C_LUT_BIT-1 downto 0):=(others=>'0');
constant step : real := 1.00/real(C_LUT_DEPTH);
begin
for count in 0 to C_LUT_DEPTH-1 loop
v_qsine_sgn := std_logic_vector(sin(MATH_2_PI*v_tstep)); --(sin (2PI/2^n))
return_lut(count) := v_qsine_sgn;
v_tstep := v_tstep + step;
end loop;
return return_lut;
end function init_lut_sin;
FvM
Super Moderator
Staff member
Bochum, Germany
Real has no representation in std_logic_vector, it's not synthesizable. Instead you need to convert real values to integer with a reasonable scaling factor and then to signed.
E.g.:
Code VHDL - [expand]
v_qsine_sgn := std_logic_vector(to_unsigned(integer(2.0**(C_LUT_BIT-1)*sin(MATH_2_PI*v_tstep)),C_LUT_BIT));
    V
TrickyDicky
Advanced Member level 5
are you trying to convert to float or fixed values?
VHDL 2008 has the fixed_pkg and float_pkg that can convert real values to either.
eg:
use ieee.fixed_pkg.all;
constant my_real_as_a_slv : std_logic_vector(15 downto 0) := to_slv( to_ufixed( 8.257, 7, -8) ); -- converts 8.257 to a 8.8 usigned fixed, then slv
    V
Toggle Sidebar
Design Fast
