Jorge Jesse Cantu
Junior Member level 1
Hi guys! I just coded a 4 to 2 priority encoder and am getting the following errors:
How do I fix these? Here is my code:
ERROR:HDLCompiler:806 - "C:\Users\Owner\Documents\vhdl\encoder\priorityencoder.vhd" Line 47: Syntax error near "process".
ERROR:HDLCompiler:841 - "C:\Users\Owner\Documents\vhdl\encoder\priorityencoder.vhd" Line 48: Expecting type void for <behavioral>.
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 library IEEE; use IEEE.STD_LOGIC_1164.ALL; entity priorityencoder is port(en_l: in std_logic; --Active low enable din: in std_logic_vector(3 downto 0); --Active high data input dv_l: out std_logic; --Valid output active low dout: out std_logic_vector(1 downto 0) --Active high data output ); end priorityencoder; architecture Behavioral of priorityencoder is signal en: std_logic; signal dv: std_logic; begin en <= not en_l; --Activation level conversion dv_l <= not dv; --Activation level conversion process(din, en) begin if(en = '1' and dv = '1') then if(din(0) = '1') then dout <= "11"; --LSB has priority if(din(1) = '1') then dout <= "10"; if(din(2) = '1') then dout <= "01"; if(din(3) = '1') then --MSB has least priority dout <= "00"; end if; elsif(en = '0') then dv <= '0'; dout <= "00"; end if; end process; end Behavioral;
