VHDL error in Quartus
Adnan86
Full Member level 2
Full Member level 2
I have this code
[B]IF x >= 1  THEN
    FOR i IN 1 TO x'length   LOOP
    ans := 10 * ans ;
    END LOOP [/B]
But i have this error :
Error (10438): VHDL attribute error at po.vhd(26): prefix of 'LENGTH attribute must be an object of array type or an array subtype
x , ans : integer ;
What can i do for solve it ?
Thanks
and if i didn't use length i have this error :
Error (10454): VHDL syntax error at p.vhd(26): right bound of range must be a constant
What do you want to achieve? An integer object hasn't a LENGTH attribute, but it has e.g. an attribute HIGH, giving the upper bound of it's range.
If you want to vary the number of iteration according to the value variable or signal, it doesn't work this way. An iteration can be only performed over a constant range. This is reasonable considering that a HDL iteration is a method to describe parallel hardware.
An iteration over the maximum range of a variable in combination with a conditional statement can achieve what you want.
