-- VHDL Architecture LAB_02_lib.HORZ_DEC_nty.HORZ_DEC_arch
-- Created:
-- by - Gerry.UNKNOWN (VIDEO)
-- at - 14:27:12 03/ 1/2012
-- using Mentor Graphics HDL Designer(TM) 2010.3 (Build 21)
LIBRARY ieee;
USE ieee.std_logic_1164.all;
USE ieee.std_logic_arith.all;
USE ieee.std_logic_unsigned.all;
ENTITY HORZ_DEC_nty IS
PORT(
clk_25Mhz : IN std_logic;
Char_Addr_Lines : IN std_logic_vector(9 downto 0); -- This is essentially just our counter "IMPUT" Bus for this Decoder Block. (The Previous BLock simply controls it to reset at 800)
State_639 : OUT std_logic;
State_659 : OUT std_logic;
State_000 : OUT std_logic;
State_755 : OUT std_logic;
State_640 : OUT std_logic;
State_799 : OUT std_logic;
State_658 : OUT std_logic;
State_756 : OUT std_logic;
Horz_sync_freq : OUT std_logic);
END HORZ_DEC_nty ;
ARCHITECTURE HORZ_DEC_arch OF HORZ_DEC_nty IS
SIGNAL SIG_horz_freq : std_logic;
SIGNAL SIG_h_count : std_logic_vector(9 DOWNTO 0);
TYPE STATE_TYPE IS (S0, S1, S2, S3, S4, S5, S6, S7);
SIGNAL state: STATE_TYPE;
BEGIN
------------------------- Horizontal Sync Frequency -----------------------------------
------------------------------- GENERATOR ---------------------------------------------
PROCESS
BEGIN
IF clk_25Mhz'EVENT AND clk_25Mhz = '1' THEN
IF (SIG_h_count <= 755) AND (SIG_h_count => 659) THEN --<<<<<<<< THIS IS LINE 48
SIG_horz_freq <= '0';
ELSE
SIG_horz_freq <= '1';
END IF;
END IF;
END PROCESS;
------------------------------ STATE SIGNALS ------------------------------------------
PROCESS (clk_25Mhz)
BEGIN
CASE state IS
WHEN S0 => -- s0 is STATE 639
IF (SIG_h_count = 639) THEN
state <= S1;
State_639 <= '1';
END IF;
WHEN S1 => -- s1 is STATE 659
IF (SIG_h_count = 659) THEN
state <= S2;
State_659 <= '1';
END IF;
WHEN S2 => -- s2 is STATE 000
IF (SIG_h_count = 000) THEN
state <= S3;
State_000 <= '1';
END IF;
WHEN S3 => -- s3 is STATE 755
IF (SIG_h_count = 755) THEN
state <= S4;
State_755 <= '1';
END IF;
WHEN S4 => -- s4 is STATE 640
IF (SIG_h_count = 640) THEN
state <= S5;
State_640 <= '1';
END IF;
WHEN S5 => -- s5 is STATE 799
IF (SIG_h_count = 799) THEN
state <= S6;
State_799 <= '1';
END IF;
WHEN S6 => -- s6 is STATE 658
IF (SIG_h_count = 658) THEN
state <= S7;
State_658 <= '1';
END IF;
WHEN S7 => -- s7 is STATE 756
IF (SIG_h_count = 756) THEN
state <= S0;
State_756 <= '1';
END IF;
END CASE;
END IF;
END PROCESS;
Horz_sync_freq <= SIG_horz_freq;
Char_Addr_Lines <= SIG_h_count;
END ARCHITECTURE HORZ_DEC_arch;
