VHDL coding style problem!!!!
dimon_k
Newbie level 2
Newbie level 2
Hi all,
I have written this lines
Code VHDL - [expand]
8
9
library ieee ;
  use ieee.std_logic_1164.all ;
  use ieee.std_logic_arith.all ;
  use ieee.std_logic_unsigned.all ;
signal wr_addr  :std_logic_vector(3 downto 0); -- fifo write address
signal rd_addr  :std_logic_vector(3 downto 0); -- fifo read address
a<= '1' when wr_addr > 6 + rd_addr else '0';
I want a to be 1 when difference between wr_addr and rd_addr is more then 6 e.g I have 6 written addresses in fifo,
but in the lab I see that it doesn't work properly.
writing :
f
ifo_lvl<= wr_addr - rd_addr ;
a<= '1' when fifo_lvl > 6  else '0';
solves the problem...
Can anybody explane what is the problem here???
thanks
Consider that 6 + rd_addr can overflow the unsigned(3 downto 0) range. Then both constructs behave different.
So you say that if rd_addr = 14 then rd_addr + 6 will be 4 because it is unsigned
Not exactly. The integer expression rd_addr +6 has the value 20. An unsigned[3 downto 0] fifo_lvl is assigned a value of 4.
