VHDL code to count leading number of 0s.
Rimon Selim
Newbie level 2
Newbie level 2
I want to design a circuit with sequential coding to count the number of leading zeros, must be sequential.
Example 00001101 has 4. Example 00000001 has 7.
Thank you for the help.
Code VHDL - [expand]
8
LIBRARY ieee ;
USE ire . std_logic_1164 . all;
ENTITY leading_zeros IS
PORT ( data : IN STD_LOGIC_VECTOR ( 7 DOWNTO 0);
zeros : OUT INTEGER range 0 to 8);
END ENTITY ;
Next steps for you would be:
- Write the architecture.
- Simulate the design
- If the output does not match what you intend AND you have attempted to debug the problem then you should:
- Post the code you have
- Write up a description of what the problem you're observing (Hint: "It's not working" will not produce any useful feedback from the group)
Good luck on your assignment.
Kevin Jennings
If "sequential" means actually a sequential circuit, counting sequentially in time, there must be a clock and probably a start signal. Or do you mean a sequential description of an asynchronous circuit, e.g. using a for loop?
Some previous threads about leading '0'/ leading '1' detectors:
https://www.edaboard.com/threads/50923/
https://www.edaboard.com/threads/201958/
Also notice the links under "Similar Threads" below.
