electrotamil
Newbie level 2
Hi every one:smile:
I'm trying to write a vhdl code for image processing application such as median filter in xilinx 10.1. i have converted my image into text file having array of hex codes using data converter and i read that file using read command. but i got a problem while writing the file. because i dono how to write result file in array format su ch as
25 FD F3 05 01 F9 FE 1E 24 EE
12 FA EF FC 12 23 FC 08 0F CC
EF F9 EE F7 1F 49 29 12 EA DC
F6 FC F9 07 04 0E 38 31 E0 0D
F8 FC F9 F0 C8 04 2D D9 E2 1D
EE 03 E6 C3 EA 15 0C CD FE 1A
DE 03 D2 D4 EB 17 FE DC 0C 39
DC FB D7 DB C5 0A EB DD 11 37
F4 EF C4 D7 C8 04 2A 02 14 07
FD ED BA C9 E6 0B 2A 20 FB E5
i used the following code
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
use std.textio.all;
use ieee.std_logic_textio.all;
---- Uncomment the following library declaration if instantiating
---- any Xilinx primitives in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity image is
generic
WIDTH : integer := 256;
HEIGHT : integer := 256 -- IMAGE_MEMORY_SIZE
--ADDR_BUS_WIDTH : integer := 16
port(clk,en:in std_logic;
INPUT_FILENAME : string := "lena.txt"; -- Note: in Test Bench Waveform, file name is -9999, so must be modified
OUTPUT_FILENAME : string := "result.txt");
end image;
architecture Behavioral of image is
file ifile:text is in "C:\Users\tamil\Desktop\image\lena.txt";
file ofile:text is out "C:\Users\tamil\Desktop\image\result.txt";
begin
process(clk,en)
type tarray is array(0 to width*height-1)of bit;
variable myline:line;
variable i:tarray;
variable b:tarray;
begin
if clk'event and clk='1' then
if en ='1' then
while not endfile(ifile)loop
readline(ifile,myline);
for n in 0 to 255 loop
read(myline,i);
b:=i;
end loop;
for m in 0 to 255 loop
write(myline,b(m));
end loop;
writeline(ofile,myline);
end loop;
end if;
end if;
end process;
end Behavioral;
but it gives in single column answer only.
more over i want to know how to read n process array of datas such as shown above n print like same
also can u any one please suggest me the corresponding command or solution for this problem:wink:
library IEEE;
use std.textio.all;
--library UNISIM;
entity image is
generic
end image;
begin
process(clk,en)
variable i:tarray;
variable b:tarray;
begin
if en ='1' then
read(myline,i);
b:=i;
end loop;
write(myline,b(m));
end loop;
end loop;
end if;
end if;
end process;
end Behavioral;
