mina.nms
Junior Member level 3
- Joined
- Sep 1, 2010
- Messages
- 29
- Helped
- 1
- Reputation
- 2
- Reaction score
- 1
- Trophy points
- 1,283
- Activity points
- 1,468
hi
would you plz help me?
what is the problem with this vhdl code for dividing two numbers by state machine?
Thanks
Thanks
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.numeric_STD.ALL; entity divi is Port ( a,b : in STD_LOGIC_VECTOR (15 downto 0); clk,e_in,res : in STD_LOGIC; e_out : out STD_LOGIC; div_out : out STD_LOGIC_VECTOR (15 downto 0); mod_out : out STD_LOGIC_VECTOR (15 downto 0)); end divi; architecture Behavioral of divi is type state is (init,divid); signal s_reg, s_next : state; signal div1,b1,dive : Unsigned (15 downto 0); signal mod1,mode: Unsigned (15 downto 0); begin process (clk,res) begin if (res ='1') then s_reg <= init; elsif (clk'event and clk='1') then s_reg <= s_next; end if; end process; process (s_reg,div1) begin case s_reg is when init => div1 <="0000000000000000"; b1 <= unsigned (b) ; mod1 <= unsigned (a) ; e_out<='0'; --if (e_in ='1') then s_next <= divid; -- end if; when divid => if (mod1>=0)then mod1<=mod1-b1; div1<=div1+1; else mode<=mod1+b1; dive<=div1-1; --div_out <= STD_LOGIC_VECTOR (dive); --mod_out <= STD_LOGIC_VECTOR (mode); e_out <='1'; --s_next <= init; end if; end case; end process; end Behavioral;
