karan123
Member level 3
- Joined
- Feb 2, 2009
- Messages
- 55
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Activity points
- 1,710
Hello,
I have spent over 2 weeks for develop code of Booth Multiplier Radix 4 and I have implemented and
tested Radix -2 booth algorithm .
But I am unable to Simulate Code for Booth Multiplexer Radix 4 . I have taken ref. from net also.
Can any body help me to guide me ? How do i Simulate ?
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 -----------------------VHDL code for booth multiplier radix 4 -------------------------------------------------------------------------------- library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_SIGNED.ALL; use ieee.numeric_std.all; ---- Uncomment the following library declaration if instantiating ---- any Xilinx primitives in this code. --library UNISIM; --use UNISIM.VComponents.all; entity booth_encoder is -- generic(N : integer:=8); Port ( a : in std_logic_vector(7 downto 0); arg : in std_logic_vector(2 downto 0); pprod : out std_logic_vector(15 downto 0)); end booth_encoder; architecture Behavioral of booth_encoder is function encoder(arg1: std_logic_vector(2 downto 0);data:std_logic_vector (7downto 0)) return std_logic_vector is variable temp,temp1,temp2: std_logic_vector(8 downto 0); variable sign: std_logic; begin case arg1 is when "001"|"010" => if data <0 then temp:='1'& data; else temp:='0'&data; end if; when "011" => if data<0 then temp1:='1'&data; temp:=temp1(7 downto 0)&'0'; else temp:='0'&data(6 downto 0)&'0'; end if ; when "100" => if data<0 then temp1:='1'&data; temp2:=(not temp1)+"000000001"; temp:=(temp2(7 downto 0)&'0'); else temp1:='0'&data; temp2:=(not temp1)+"000000001"; temp:=(temp2(7 downto 0)&'0'); end if; when "101"|"110" => if data < 0 then temp1:='1'&data; temp:=not(temp1)+"000000001"; else temp1:='0'&data; temp:=(not temp1)+"000000001"; end if; when others => temp:="000000000" ; --"(others=>'0'); end case; return temp; end encoder; signal s1: std_logic_vector(8 downto 0); signal s2: std_logic; begin s1<=encoder(arg,a); end Behavioral;
