Very Urgent Problem with PIC
hassan1980
Full Member level 4
Full Member level 4
Happy New Year To You All.
I have a problem :
The PIC 16F84A affects with turning on Flourisent neon at my room.
Would please let me know how to solve this problem.
Improve the power supply noise rejection for the PIC: 100nF decoupling caps as close to PIC pins as possible, insert a 10uF decoupling cap + 100uH choke + 10uF decoupling cap in the power supply line to the PIC...
Generally PICs are a lot less affected by such noise as compared to some other architechtures. But if you still get this problem, try putting some EMI filters in the circuit. In addition to what rfmw as told you, also use ferrite beads / rings on the cables entering and leaving the circuit. For example, put a ring (in common mode) on the 2 power wires and similarly on signal wires.
Would you please uplaod schematic for the above explanation?
on the other hand, What EMI Filters?
see the attached pcb
You know, it would help if you would write some more about your project. What we really know is that you use PIC and have trouble with it...
I made a project for Hokey Game, then this hokey game has a switch to start a game.
the problem is when I turn on the Flourisent neon the game start without pressing the start switch.
I give you example :
scan btfss porta,0
goto scan
scan1 btfsc porta,0
goto scan1
start game
that lead me to say, logically the pic mustn't goto start game if I don't press the switch then it is affect by turning on Flourisent neon.
Hope I explain the problem.
Would you please let me know what is the problem?
I understand your problem now. How do you connect the switch to the PIC? Do you use any debounce circuits? I hope that your wires from the switch to the PIC are short...
Attach your schematic and picture of the device if possible. It might be that EM noise produces a spike in your switch wires, therefore PIC senses it as if you've pressed a switch, while you really didn't...
you must put a 100nF capacitor from input pin and ground and pull up or pull down (220 ohm) resistor from input pin and power line .
I prefer make input normally pull-up with a diode 1N4148 connect series with the external switch (switch give negative when push) and i use a debounce software filter of 100mS
