I see what you mean.ram said:Sorry guys i cant do that..its company property. But here is some idea i will give how it works.
I am taking the library information from user. This information is library cell name & its equation in verilog form. If the cell can not be representated by equation then take a statement format this is taken using perl module (.pm file). Now read your netlist statement by statement.
For every cell instance in netlist replace it by the equation or statement taken from user. Here you have to change the pin name in equation or statement with the corrousponding instance pin name.
While doing this you have to take care of wild characters added by synopsys sush as /*cell* etc. Some function is necessary to replace such charcters by nonexisting name.
You may need to create new net (wire to connect 2-3 statements for one instance of tech. Lib cell).
By using this you can create a script. The script i have created is technilogy library specific. That will convert netlist in that technology to rtl.
The use of this convertion...can any guess?
Hope this will help you.
