[SOLVED] Verilog: What is the proper way to write a test module?
Alper özel
Turkey / Scotland
I am trying to write an SPI master module on my own to learn FPGA-Verilog efficiently.
This is my spi_master module:
module spi_master(
		input [15:0] tx_data,
		output [15:0] rx_data,
		output mosi,
		input miso,
		output cs,
		output sck,
		input start,
		input clk
	 wire [15:0] tx_data;
	 reg [3:0] tx_counter;
	 reg [3:0] rx_counter;
	 wire start;
	 reg cs;
	 reg mosi;
	 reg [15:0] rx_data;
	 wire miso;
	 reg sck;
	 reg [3:0] clk_divider;
	 initial begin
	 clk_divider [3:0] = 4'b0;
	 tx_counter [3:0] = 4'b0;
	 rx_counter [3:0] = 4'b0;
	 cs = 1;
	 sck = 0;
	 end
	always @(start) begin
		if (clk_divider == 4'b1000) begin   // divided by 8
			sck =  ~sck;
		end
		if (clk_divider >= 4'b1000) begin
		end
		else begin
			#1 clk_divider = clk_divider + 4'b1;
		end
	end
	always @(negedge sck) begin
		if (cs == 0 && tx_counter != 4'b1111) begin
			#(clk_divider/2) mosi <= tx_data[tx_counter];
			#(clk_divider/2 + 1) tx_counter <= tx_counter + 4'b1;
		end
		else if(cs == 0 && tx_counter == 4'b1111) begin
			#(clk_divider/2) cs <= 1'b1;
		end
		else if (cs == 1 && tx_counter == 0) begin
			#(clk_divider/2) cs <= 1'b0;
		end
	end
	always @(posedge sck) begin
		if (cs == 0 && tx_counter <= 4'b1111 && tx_counter >= 4'b0001) begin
			#(clk_divider/2) rx_data[rx_counter] <= miso;
			#(clk_divider/2 + 1) rx_counter <= rx_counter + 4'b1;
		end
	end
endmodule
and this is my test module:
`include "spi_master.v"
module spi_master_tb(
reg clk;
reg start;
wire mosi;
reg miso;
reg cs;
reg sck;
reg [15:0] tx_data;
//reg [15:0] rx_data;
initial begin
clk = 0;
tx_data = 16'hF0AA;
#20 start = 1'b1;
miso = 1;
#1000 $finish;
end
always begin
	#1 clk = ~clk;
end
spi_master SPI_block(
		tx_data,
		rx_data,
		mosi,
		miso,
		cs,
		sck,
		start,
		clk
endmodule
The problem is test module seem like not communication with the spi module(as seen in the picture). When you check the ISim diagrams, clk is working and any initialization on test module is working(Start, miso) but Tx_data is not passed to mosi and sck is not dividing clk. Where am I doing wrong? I can understand the other s not working but sck is pretty easy don't you think?
I appreciate any help. Thanks.
problem 1 you can't create asynchronous counters if you want something that will actually work on hardware. Verilog isn't like C programming it's a hardware description language and the bellow code does not describe a counter.
			sck =  ~sck;
		end
		end
		else begin
		end
	end
Your counter also doesn't do a divide by 8 it's a divide by 9.... 0,1,2,3,4,5,6,7,8 (there are 9 values before it repeats)
The #1 has no place in synthesizable code in my opinion. Besides that you don't have the timescale defined for this anywhere in the posted code. From the waveform it looks like it's defaulted to 1ns probably 1ns/1ps. So your clock is 500 MHz which is highly unlikely for SPI.
SCK doesn't toggle because both the initial value is X and stays X as there is no statements initializing it to a value at the start of simulation (not necessarily synthesizable) or a reset on the flip-flop generating it.
The typical way to "do" SPI is to use a much faster clock. You then sample the SPI bus (slave) and generate the SPI signals (master) using that faster clock domain. The only time you don't do this is if you have a design that does not have any clocks available when starting up, e.g. a design that programs the board VCOs that are used by the FPGA/CPLD. In such a case you have to use the SPI clock to run the slave interface.
I'm sure there are other problems, but I only glanced at your code.
Edit...
Don't use positional port assignments it's a really bad practice and can render code un-maintainable or at minimum make it really easy to add a port and end up with a design that is no longer connected correctly. Instead use the named port association syntax.
e.g.
  .tx_data (tx_data),
  .rx_data (rx_data),
  .mosi    (mosi),
  .miso    (miso),
  .cs      (cs),
  .sck     (sck),
  .start   (start),
  .clk     (clk)
If you add a new port it doesn't matter where you add the line assigning the new connection to the module.
Thanks for such detailed answer. But I thought that I initialized sck in the line:
	 initial begin
	 cs = 1;
	 sck = 0;
	 end
does not that cover it?
Also, to make a hardware counter is this the way?
	always @(posedge clk) begin
			if (!clk_divider != 3'b111) begin
				clk_divider <= clk_divider + 1;
			end
			else
				clk_divider <= 3'b0;
			end
	end
Didn't see the sck initialization, the X is probably a result of the asynchronous counter, which won't simulate correctly. Your new counter code has an extra ! before the clk_divider in the if expression.
I would probably code this counter with a reset like this..
  if (rst)
    clk_divider <= 0;
  else
end
you don't need to set it back to 0 as the counter will rollover without requiring any compare operations. Or a more generic counter.
parameter N = 8; // maximum number of counts (does not need to be 2^N)
  if (rst)
    clk_divider <= 0;
  else if (clk_divider < N-1)
  else
    clk_divider <= 0;
end
