verilog syntax error
tok47
Full Member level 1
Kuala Lumpur, MALAYSIA
Hi ALL,
I having a verilog compilation error. Need help adn guidance.
I have a instance connected as below,
USB_A0 U1 (
.PLLDIVM(1'b0),
.PLLDIVK[1](1'b0),
I have a compilation error :
Error-[SE] Syntax error
token is '['
Can I know how to solve this?
Thanks.
Rdgs
YY
Verilog LRM says:
12.3.6 Connecting module instance ports by name
The second way to connect module ports consists of explicitly linking the two names for each side of the connection: the port declaration name from the module declaration to the expression, i.e., the name used in the module declaration, followed by the name used in the instantiating module. This compound name is then placed in the list of module connections. The port name shall be the name specified in the module declaration. The port name cannot be a bit-select, a part-select, or a concatenation of ports. If the module port declaration was implicit, the port_expression shall be a simple identifier or escaped identifier, which shall be used as the port name. If the module port declaration was explicit, the explicit name is used as the name of port.
In other words, you can only use a simple port name (e.g. PLLDIVK) on the left side of the named port connection. If the port is a vector, you have to specify an expression for all bits in the paranthesis.
USB_A0 U1 (
.PLLDIVM(1'b0),
.PLLDIVK({1'b0,1'b0}), //For a 2 bit vector connection
