acey80
Newbie level 6
verilog decoder schemantic
hi all,
i'm actually doing a project that includes the 3-8 decoder. while some of u think a 3-8 decoder has a simple schematic with the standard truth table, which is:
the schematic should be like:
now, what if the truth table is like this?
the idea is to turn on multiple-same-capacitance value at the same time to have a bigger capacitance. so that, the layout person won't have to create different value of capacitance. thus, only 1 standard capacitance value is created.
ok then, since i have problem to generate the schematic out from the truth table manually, i have to use verilog code and let the Synopsis software to generate the schematic for me. and so, let's say the input is, is this the correct verilog code????
module decoder (sel,y);
input [0:2] sel;
output [0:7] y;
reg [0:7] y;
always @ (sel)
begin: decode
case (sel)
3'b000: y=8'b00000001;
3'b001: y=8'b00000011;
3'b010: y=8'b00000111;
3'b011: y=8'b00001111;
3'b100: y=8'b00011111;
3'b101: y=8'b00111111;
3'b110: y=8'b01111111;
3'b111: y=8'b11111111;
default: y=8'bxxxxxxxx;
endcase
end
endmodule
i've tried the code and the output is as followed:
isn't quite weird? only 6 outputs...i'm expecting 8 outputs.... my friend told me the synopsis already optimize the circuit to a simpler version!
How's that? is it true then?
pls help. Thanks in advance...
p/s: i'm not used to verilog and Synopsis... only small part of the project uses digital parts...
hi all,
input [0:2] sel;
output [0:7] y;
reg [0:7] y;
always @ (sel)
begin: decode
case (sel)
endcase
end
endmodule
