Verilog : how to use module as global module
ghazalaz
Newbie level 2
Newbie level 2
Verilog : how can i use a module as global module?
hi,
i wanna use some 2d array of registers as global in some module and change them sometime , i define them in module named memory like this:
PHP:
module memory();
  reg [31:0]Inst_Mem[31:0];
  reg [31:0]Data_Mem[31:0];
  reg [31:0]RF[31:0];
  reg [5:0]PC;
end module
now i want to use these memories in another module (named run) and make changes to them,
PHP:
module run( input [31:0]Ins );
  reg clk;
  initial begin
   clk = 0;
  end
  initial repeat(100)#5 clk = ~clk;
  always @(posedge clk)
  begin
    memory.PC[5:0] = memory.PC + 6'b000001 ;
  end
endmodule
i even can't pass them as inout parameter because they're 2d reg array
so what can i do? :-/
how can i initialize and make change to them in any module?
i will be so thankful if anybody can help (please:D) :)
Re: Verilog : how can i use a module as global module?
Code Verilog - [expand]
module memory();
  reg [31:0]RF[31:0];
  reg [5:0]PC;
end module
Well, your "memory" module has no input or output ports. In HDL country that is the equivalent of a black box ... which you then throw in a black hole, never to be seen again. Nothing goes in, nothing comes out.
For a two in one educational moment, see for example this: https://www.asic-world.com/verilog/para_modules1.html
One, you get to see how to do inputs/outputs for your modules. Two, you get parameterization thrown in for free. Woohoo!
