Verilog Help (quote mark)
jihadmoussa
Newbie level 5
can somebody please explain the following assign for me:
bit_counter <= `COMMAND_BITS;
I couldn't know what does the quote mark do?
thank
`define COMMAND_BITS 4
Does the same as:
bit_counter <= 4;
But with regard to coding style, you will probably want to use the "parameter" or "localparam" verilog directive for that.
parameter COMMAND_BITS = 4;
bit_counter <= (COMMAND_BITS); // better style IMO
Hope that helps.
Reactions: jihadmoussa
    V
    jihadmoussa
Thank you very much.
you were really helpful.
thanks again.
