Verilog codes for clock divider
kaiser
Newbie level 5
I have a 50 Mhz clock on my board and i need a 60Hz clock for my design......
Somebody can suggest anything to do...?
A verilog descripiton it will be very nice....(with comments- general mods)
THX IN ADVANCE!!
nand_gates
Advanced Member level 3
verilog code to measure the clk frequency
Here goes the Verilog code!
module clk_div(clk_50mhz, rst_n, clk_60hz);
   input clk_50mhz, rst_n;
   output      clk_60hz;
   reg         clk_60hz;
   reg [47:0]  counter;
   always @(posedge clk_50mhz or negedge rst_n) begin
      if (!rst_n) begin
         counter <= 48'h00000;
         clk_60hz <= 1'b0;
      end else begin
        if (counter == 48'h65B9A) begin
           clk_60hz <= ~clk_60hz;
        end else begin
           counter <= counter + 1'b1;
        end
      end // else: !if(!rst_n)
   end // always @ (posedge clk_50mhz or negedge rst_n)
endmodule // clk_div
    kaiser
sp
Full Member level 6
Floating Garden
Re: CLK Divider HELP
i get it from one university... dunno its name D...
VHDL
If you need a slower clock, here is a simple clock divider algorithm, that divides the clock by 2N.
Where :
N = f(clk) / (2* f(desired))
-- file "clk_div.vhd"
-- a generic clock divider, divides by 2*N
-- adapted from "VHDLL Primer" by J. Bhasker, p. 295
library ieee;
use ieee.std_logic_1164.all;
entity clk_div is
  generic(N: positive:= 2);
  port
    (fast_clk, reset: in std_logic;
     slow_clk: buffer std_logic
end clk_div;
architecture behavioural of clk_div is
begin
  process(reset, fast_clk)
    variable count: natural;
  begin
    if reset = '1' then
       count := 0;
       slow_clk <= '0';
    elsif rising_edge(fast_clk) then
       count := count + 1;
          if count = N then
             slow_clk <= not slow_clk;
             count := 0;
          end if;
   end if;
  end process;
end behavioural;
regards,
sp
    kaiser
angelote
Spain
if (!rst_n) begin
You will need dual edge filp-flop. Is your CPLD/FPGA capable?[/u]
    kaiser
adap
Member level 5
if (!rst_n) begin
There is no need to use dual edge flip-flop. That part of the verilog code is as writing in VHDL the following:
process(clk_50mhz, rst_n)
  begin
    if reset = '0' then
   elsif rising_edge(clk_50mhz) then
    kaiser
kaiser
Newbie level 5
Thank you very much....
it was helpfully..
After i was looking over your suggestions, i made this(from 50Mhz downto 1Hz with 50% dutty cycle)
module clk_div ( clk_in, reset,clk_1hz);
input clk_in, reset;
output clk_1hz;
reg clk_1hz;
reg [25] counter;
always @(posedge clk_in or posedge reset)
begin
if (reset)
begin
counter <= 26'h0;
clk_1hz <= 1'b0;
end
else
begin
if (counter == 26'h17D7840)
begin
counter <= 26'h0;
clk_1hz <= ~clk_1hz;
end
else
end
end
endmodule
any comments it will be appreciated...
Added after 11 minutes:
   output      clk_60hz;
   reg         clk_60hz;
   reg [47:0]  counter;
      if (!rst_n) begin
         clk_60hz <= 1'b0;
      end else begin
        end else begin
        end
Thank you for your code....
But i dont understand something.......when i divide from 50 Mhz downto 60 hz ..well...i need "800.000 cycle of 50 MHz clock" /2= 400.000
and 400.000 = 48'h61A80 and in your code it a little bigger..so is not exactly 60Hz...right?
Why do you do that...? It's a trick and i dont know about it?
echo47
Advanced Member level 5
USA
CLK Divider HELP
50 MHz does not divide evenly to 60 Hz. The ratio is 833333.333...
You could build a counter that counts up from 0 through 2499999 and outputs a pulse as it passes 0, 833333, and 1666666. That will give you three pulses every 2500000 clocks which is exactly 60 Hz. But the pulses are not evenly spaced, there is one-cycle jitter (20 ns).
module top (clk, hz60);
  input             clk;
  reg        [21:0] count = 0;
  output reg        hz60 = 0;
  always @ (posedge clk) begin
    count <= (count == 2499999) ? 0 : count + 1;
    hz60 <= (count == 0) | (count == 833333) | (count == 1666666);
  end
endmodule
If you can't tolerate the 20 ns jitter, then you need to use a DLL or PLL to change the 50 MHz into something that can be divided cleanly.
omara007
Cairo/Egypt
How will it exactly be 60 Hz ? ..
don't you measure the frequency on ONE cycle basis ? .. can you tell me the duty cycle ?
echo47
USA
CLK Divider HELP
My counter has 20ns period jitter. The period is 16666660ns, 16666660ns, 16666680ns, and then it repeats. The average of those three periods is 16666666.6666... nanoseconds, which is exactly 60 Hz.
Even the best clock oscillators have some jitter (usually picoseconds) due to thermal noise. You should always measure a clock's frequency by averaging many cycles.
mountain
Member level 2
   output      clk_60hz;
   reg         clk_60hz;
   reg [47:0]  counter;
      if (!rst_n) begin
         clk_60hz <= 1'b0;
      end else begin
        end else begin
        end
1.
In the port definition, thers is
output clk_60hz;
reg clk_60hz;
why the "reg clk_60hz;" is needed? I met this type many times, but I don't know the reason.
2.
The counter is so long(48bit), so it will work well?
echo47
USA
CLK Divider HELP
mountain,
1. Without the reg statement, the output signal would default to a wire instead of a register.
You can combine the two statements: output reg clk_60hz;
2. No, 48 bits is overkill. The upper 29 bits are always zero.
By the way, this module does not generate 60 Hz. It generates approximately 59.999952 Hz.
blueskystone
CLK Divider HELP
if (!rst_n) begin
this design is ok , it is just an asynchronous RESET
, not a dual edge filp-flop.
it's suit for CPLD/FPGA .
kumar_eee
Bangalore,India
Can any1 explain abt Clock Doubler & How to implement it?....
echo47
USA
Implement it in what type of chip?
Modern FPGAs have built-in frequency synthesizers, such as the DCM in Xilinx devices. These can be used to multiply/divide the input clock frequency by various ratios.
