Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 --Program for HAMMING CODE TRANSMISSION & RECEPTION . -- ( generating Hamming code parellely , ssending it serially & -- receiving it parallely for error detecttion & correction.) --(IMPORTANT:- ASSIGN THAT PIN OF THE CPLDD TO THE CLK I/P BY WHICH YOU CAN TOGGLE THE -- CLOCK WITH A SWITCH PROVIDED ON THE CPLLD BOARD.) library IEEE; use IEEE.std_logic_1164.all; use IEEE.std_logic_arith.all; use IEEE.std_logic_unsigned.all; entity hammgen is port ( d: in STD_LOGIC_VECTOR (3 downto 0); -- i/p message bits clk:in STD_LOGIC; -- Clock i/p ten:in STD_LOGIC; -- transmitter-enable(Mux enable) err:in STD_LOGIC; -- error introducing i/p ren:in STD_LOGIC; -- receiver-enable(Demux enable) dh: out STD_LOGIC_VECTOR (7 downto 1); --Detected & corrected Hamming code. error:out STD_LOGIC_VECTOR (6 downto 0) -- 7-segment o/p for displaying error. ); end hammgen; architecture hammgen_arch of hammgen is signal h: STD_LOGIC_VECTOR (7 downto 1); signal mh :STD_LOGIC; signal dmh:STD_LOGIC_VECTOR(7 downto 1); signal sipoh: STD_LOGIC_VECTOR (7 downto 1); signal ripoh: STD_LOGIC_VECTOR (7 downto 1); signal sum1 : STD_LOGIC; signal sum2 : STD_LOGIC; signal sum4 : STD_LOGIC; signal p1 : STD_LOGIC; signal p2: STD_LOGIC; signal p4 : STD_LOGIC; signal en: STD_LOGIC_VECTOR (7 downto 1); signal sum5: STD_LOGIC; signal sum6: STD_LOGIC; signal sum8: STD_LOGIC; signal y: STD_LOGIC_VECTOR (7 downto 0); signal countx:STD_LOGIC_VECTOR (2 downto 0); signal countr:STD_LOGIC_VECTOR (2 downto 0); begin -- Program module for HAMMING CODE GENERATTION . process (sum1,sum2,sum4,p1,p2,p4,d) begin sum1<=d(0) xor d(1) xor d(3); -- Parity bits are found here. sum2<=d(0) xor d(2) xor d(3); sum4<=d(1) xor d(2) xor d(3); if sum1='0' then p1<='0'; else p1<='1'; end if; if sum2='0' then p2<='0'; else p2<='1'; end if; if sum4='0' then p4<='0'; else p4<='1'; end if; end process; h(1)<=p1; --The parity bits found out in the above process block h(2)<=p2; -- are put in a register 'h'(declared as signal). h(3)<=d(0); h(4)<=p4; h(5)<=d(1); h(6)<=d(2); h(7)<=d(3); -- Program module for Mux & xmit count & iintroducing error. process (clk,countx,ten) -- A 3-bit up counter o/p (countx) is connected begin -- to the Select lines of the Mux which will if clk 'event and clk='1' then -- increment the ststus of the Select lines if ten='1' then -- automatically . if (countx <"111"or countx="111") then countx<=countx+1; else countx<="000"; end if; else countx<="ZZZ"; end if; end if; end process; process(countx,clk,h,err,mh) -- In this part the Hamming code bits are sent begin -- thro' the Mux . If the err i/p is =1 error if clk'event and clk='1' then -- is introduced in the hamming code bit (means case countx is -- that bit is complemented.) when "000"=> -- mh is Mux o/p. if err='0' then mh<=h(7); else mh<=not h(7); end if; when "001"=>mh<=h(6); if err='0' then mh<=h(6); else mh<=not h(6); end if; when "010"=>mh<=h(5); if err='0' then mh<=h(5); else mh<=not h(5); end if; when "011"=>mh<=h(4); if err='0' then mh<=h(4); else mh<=not h(4); end if; when "100"=>mh<=h(3); if err='0' then mh<=h(3); else mh<=not h(3); end if; when "101"=>mh<=h(2); if err='0' then mh<=h(2); else mh<=not h(2); end if; when "110"=>mh<=h(1); if err='0' then mh<=h(1); else mh<=not h(1); end if; when others=>Null; end case; end if; end process; -- Program module for De-mux & rec. count . process(ren,clk,countr,mh) --process(r,clk,ren,ch,countr) begin if clk 'event and clk='1' then -- A 3 bit counter o/p if ren='1' then -- similar to the mux, if ( countr<"111"or countr="111" ) then -- is given to the select countr<=countr+1; -- lines. dmh<=mh&dmh(7 downto 2) ; -- Here serial to parellel else -- conversion of the received countr<="000"; -- serial hamming code from the -- mux(i.e. mh signal), is made. end if; --(Shift register concept) else countr<="ZZZ"; dmh<="ZZZZZZZ"; end if; end if; end process; sipoh<=dmh; -- When the serial data (mh) is shifted to make it parallel -- the MSB goes into the LSB position. So the shifted bits -- of dmh(Demux o/p) which are stored in ssipoh register ripoh(7)<=sipoh(1); -- (declared as signal) are put into the ripoh register ripoh(6)<=sipoh(2); -- (declared as signal) in reverse order. ripoh(5)<=sipoh(3); ripoh(4)<=sipoh(4); ripoh(3)<=sipoh(5); ripoh(2)<=sipoh(6); ripoh(1)<=sipoh(7); -- Program for HAMMING CODE DETECTION . sum5<=ripoh(1) xor ripoh(3) xor ripoh(5) xor ripoh(7); -- Error detection part sum6<=ripoh(2) xor ripoh(3) xor ripoh(6) xor ripoh(7); sum8<=ripoh(4) xor ripoh(5) xor ripoh(6) xor ripoh(7); y(0)<=not sum8 and not sum6 and not sum5; -- Decoder is used to decode y(1)<=not sum8 and not sum6 and sum5; -- the position of the bit in error. y(2)<=not sum8 and sum6 and not sum5; y(3)<=not sum8 and sum6 and sum5; y(4)<= sum8 and not sum6 and not sum5; y(5)<= sum8 and not sum6 and sum5; y(6)<= sum8 and sum6 and not sum5; y(7)<= sum8 and sum6 and sum5; en(1)<=y(1); -- The decoder o/p lines are given to the en(2)<=y(2); -- enable (en, which is declared as a signal) i/p en(3)<=y(3); -- of an inverter so as to complement the bit in en(4)<=y(4); -- in error. Complementing is done in the next en(5)<=y(5); -- process block . en(6)<=y(6); en(7)<=y(7); process( en,ripoh) begin case en is -- 7654321 when "0000001"=>dh<=ripoh(7 downto 2)& not ripoh(1); -- Only the bit in error is complemented when "0000010"=>dh<=ripoh(7 downto 3)& not ripoh(2)& ripoh(1); -- Rest are kept unchanged. when "0000100"=>dh<=ripoh(7 downto 4)& not ripoh(3)& ripoh(2 downto 1); when "0001000"=>dh<=ripoh(7 downto 5)& not ripoh(4)&ripoh(3 downto 1); when "0010000"=>dh<=ripoh(7 downto 6 )& not ripoh(5)& ripoh(4 downto 1); when "0100000"=>dh<=ripoh(7)& not ripoh(6)& ripoh(5 downto 1) ; when "1000000"=>dh<=not ripoh(7)&ripoh(6 downto 1); when "0000000"=>dh<=ripoh; when others=>Null; end case; end process;
I am having code for same in VHDL .Check it out whether it is useful to you or not.
If USEFUL PLEASE PRESS HELP BUTTON.
Code for Hamming Distance Transmission & Reception.
