Verilog case :- unexpected behaviour
otis
Member level 3
I have a following code
module test(clk,out1,out2)
  input      clk;
  output     out1,out2;
  reg        out1,out2;
  reg [1:0]  next_state;
  parameter [1:0] ONE   = 2'b00,
                  TWO   = 2'b01,
                  THREE = 2'b10,
                  FOUR  = 2'b11;
  paramter  ON  = 0,
            OFF = 1;
  always @ (next_state)
  begin
      out1 <= next_state[ON];
      out2 <= next_state[OFF];
  end
 always @(posedge clk or posedge rst)
 begin
   if (posedge rst)
     next_state <= ONE;
  else
    case (next_state)
      ONE    : next_sate <= TWO;
      TWO    : next_sate <= THREE;
      THREE  : next_sate <= FOUR;
      FOUR   : next_state <= ONE;
    endcase
 end
Above is my simplified version of my current code... Original code exactly the same structure.
control goes to case ONE after reset and next_state gets value TWO. Then I expect that on next clock the next_state will get THREE and so on.
But in my case all assignments happens at same clock edge. I means at same edge next_state updated with ONE,TWO,THREE and FOUR. I found this by adding display comment on every case value.
What is wrong?
Hi, I tried your code.
There were a few syntax errors, but after fixing them it appeared to simulate ok. I think it was your reset...
See attached casetest.tar . Pull up the vcd file to see the sim results.
A couple of things:
1) your rst control did not appear to be working properly; see modified test.v; i am guessing you wanted a synchronous active high reset...
2) more importantly, you do not have a default for your case statement; this won't break
simulation, but you may have problems comparing RTL to synthesized gates...always have a default for case statements; my preferred way is have the default to be X so that you can catch missed states easily
  • casetest.tar
Reactions: otis
    otis
Thanks for your time....Really appreciate that!!!
In my case there was one signal which I used in sensitivity list without initializing... After fixing that one my issue has gone....
