Verilog : bit mask to index converter
madushan
Hi guys,
Can anyone please help me to design the following circuit
let's say that there's an array of 4 bits (the width of this array should be parameterizable)
I need to find the index of the first occurrence of a '1' in this array when searched from the least significant bit
So
if array is 0100 module should return index 2
if array is 1100 module should return index 2
if array is 1110 module should return index 1
if array is 1111 module should return index 0
I need to do this in combinational manner
please help
Thanks
I can simply use a series of if else if statements, like
if (array[0]) begin
   index <= 0;
end
else if (array[1]) begin
   index <= 1;
end
else if (array[2]) begin
   index <= 2;
end
Thss doesn't suit here because the width of this array must be parameterizable, it can be 5, 6, 32, 64, etc
What should the result be if there are no bits set?
oh sorry,
if the all the bits are 0s, index should be 0
so this changes to
if array is 0100 module should return index 3
if array is 1100 module should return index 3
if array is 1110 module should return index 2
if array is 1111 module should return index 1
hmm, my first thought is to (-x) & (x), which returns the rightmost set bit as a vector:
0011101000 = x
1100010111 = ~x
1100011000 = -x
0000001000 = -x&x
This might be helpful if x is locally generated (the -x infers an adder which is a local structure and may cause routing bottlenecks in some cases). If you don't need an encoded version, this may work well.
This is synthesizable because there is an upper bound on the number of loops, but I don't know if all synthesis tools support this:
SystemVerilog
parameter SIZE = 10;
bit array[SIZE];
int i;
always_comb
    begin
       i=0;
       while (i<SIZE && !array[i]) i++;
    end
Verilog
reg array[0:SIZE-1];
integer i;
always @(array);
    begin
       i=0;
       while (i<SIZE && !array[i]) i=i+1;
    end
