[SOLVED] Verilog - array and vector access
pbernardi
Full Member level 3
Hello all,
I would like to access part of a vector, in a wire that is also an array. Is it possible somehow?
For example, the example below is not valid (I just make the code now by head, so sorry for any possible inconsistence):
wire [15:0] a[2:0];
genvar i;
for (i=0;i<8;i=i+1)
always @*
begin
  case (a[15:14][i])
  endcase
end
while this is valid
wire [15:0] a;
always @*
begin
  case (a[15:14])
  endcase
end
is there a way to address this? I know that I cannot access a slice of an array, but I want to access a slice of a vector that is also an array.
The slice of the vector is last.
case (a[i][15:14])
Great, just a syntax problem. Thank you.
