Verify my dspic30f code for serial communication
hansika
Member level 2
hyderabad
hi all,
i have write a code in mikroC IDE for serial communication dspic30f6014A when i am sending a character say 's' to PC i am not getting that correctly i have set the baud rate in pc and in dspic same only . below is my code please verify and suggest me where i am doing wrong
unsigned rx1;
void main()
//LATB=0;
//ADPCFG=0xFF;
TRISB=0;
LATBBITS.LATB0=1;
LATBBITS.LATB1=1;
Uart_Init_Advanced(9600,0,0);
Uart_Write_Char('s');
while(1)
if (Uart1_Data_Ready())
rx1 = Uart_Read_Char();
Uart_Write_Char(rx1);
when i am sending character 's' i am getting some junk value . i am dumped the code using winpic800.
Re: dspic30f issue
I usually use microchip C30 compiler .But with a Uart init routine .You should read what else needs to be initialized on the Dspic .Those chips have lots of stuff.They have to be carefully initialized .Otherwise you end up in problems like the one you have .You need to read the compiler doc for that routine as well as understand with the particuliar Datasheet what is required to have that baudrate that you need.
So is not an issue is just a work to do from your part.
