verify functionality and calculate fmax for Altera IP
abd_elhamid_
Newbie level 6
How can I get the fmax for a IP block created from Quartus Megafunction(such as lpm_add_sub)? also if there is a way to verify operation instead of writing test bench.
Note: I created lpm_add_sub block and started compilation, but I found "No paths to report" at fmax summary, I don't know the problem .
Any help.
Thanks
To get the fmax, you need a pipe depth of at least 2, because fmax comes from register to register path.
For a single mega wizard block, you can usually assume it will work as advertised, especially the lpm blocks, because they have a very long history. If you want to verify it, you will need a test bench.
