Engineer4ever
Member level 3
I designed a 5-stage VCO using maneatis delay cell to produce ten spaced clocks at 1.6GHz. The problem is, the output clocks don't have the same frequency, there is a difference that ranges between 60~90 MHz between each two clocks. How is that possible? The five cells are replica of each other with the same sizes and biasing.
Thanks,
Thanks,
