various error in programming with vhdl
chaitanya.531
plz
Need a little help here with my VHDL code.
I'm new to VHDL so please bear with me.
I'm getting the following Error messages for my code posted below. (I'm using the xilinx 8.1.03i and modelsim )
When I run check syntax, the following is displayed
eRROR:HDLParsers:164 - "C:/Xilinx/rcc2/fg/rc5round.vhd" Line 62. parse error, unexpected COLON, expecting COMMA or CLOSEPAR
code is given by
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity rc5round is
port (
        si : in  std_logic_vector(31   downto 0); --  subkey
        di  : in  std_logic_vector(63 downto 0); -- data in
        do  : out std_logic_vector(63 downto 0);  -- data out
        clk : in std_logic                       -- clk
end rc5round;
architecture Behavioral of rc5round is
component addsub
port ( a , b   : in std_logic_vector (31 downto 0);
      encdec  : in std_logic;
		c       : out std_logic_vector (31 downto 0));
end component;
component circularshift
port (
        sn     : in  std_logic_vector(5 downto 1);
        di     : in  std_logic_vector(31 downto 0);
        encdec : in std_logic ;
        do     : out std_logic_vector(31 downto 0)
end component;
component dff
port(	  d    :	   in   std_logic_vector (31 downto 0);
	   clk  :		in std_logic;
	     q    :	   out std_logic_vector (31 downto 0)
end component;
component mux2b1
port  (  d1 : in std_logic_vector (31 downto 0);
         d2 : in std_logic_vector (31 downto 0);
		   encdec: in std_logic;
		   dout  : out std_logic_vector (31 downto 0)
end component;
component xrgate
   port ( a ,b : in std_logic_vector (31 downto 0);
end component;
signal dr,dl : std_logic_vector(31 downto 0);
signal da,cs : std_logic_vector(31 downto 0);
signal m1,xo : std_logic_vector(31 downto 0);
signal m2,ao : std_logic_vector(31 downto 0);
signal cs,m3 : std_logic_vector(31 downto 0);
begin
  dl <= di(63 downto 32);
  dr <= di(31 downto 0);
d1: dff  port map ( dr, clk, dl );
d2: dff  port map ( dl, clk, da );
m1 : mux2b1 port map ( cs, da, encdec ,m1 );
m2 : mux2b1 port map ( ao, xo, encdec ,m2 );
m3 : mux2b1 port map ( da, cs,encdec ,m3 );
m4 : mux2b1 port map ( xo, ao, encdec ,dl );
x1  : xrgate port map ( dl,m1,xo );
a1 : addsub port map (m3, si, encdec, ao);
c1 : circularshift port map (dl(4:0), m2, encdec, cs);
end Behavioral;
library IEEE;
entity mux2b1 is
end mux2b1;
architecture Behavioral of mux2b1 is
begin
process (encdec) is begin
if  encdec = '1' then
dout <= d1;
else
dout <= d2;
end if;
end process;
end Behavioral;
library IEEE;
entity addsub is
end addsub;
architecture Behavioral of addsub is
begin
process (a,b,encdec) is begin
c <= a + b;
else
c <= a - b;
end if;
end process;
end Behavioral;
Not referring to known VHDL syntax. You mean 4 downto 0?
Telling the exact error location would be general helpful.
In addition to FvM suggestion
Remove twice declared CS in signals(remove one cs )
and add encdec signal
ya i get it
when i synthisis following warring occurs
WARNING:Xst:819 - "C:/Xilinx/rcc2/fg/rc5round.vhd" line 55: The following signals are missing in the process sensitivity list:
WARNING:Xst:819 - "C:/Xilinx/rcc2/fg/mux2b1.vhd" line 18: The following signals are missing in the process sensitivity list:
WARNING:Xst:819 - "C:/Xilinx/rcc2/fg/circularshift.vhd" line 29: The following signals are missing in the process sensitivity list:
plz tell me how to get out of this wring
add the missing signals to the process sensitivity list.
